I've owned my Samsung LN-S4092D TV just over a year now and it has started exhibiting multicolored horizontal lines that extend across the entire screen and appear at different points on the screen depending on the input signal. Each line is about a pixel wide.
EX: A 720p input has several of these lines bunched together near the bottom of the screen and several other are bunched toward the middle.
A 1080i input has several more lines than a 720p input signal
An SD signal (cable/ antenna/ DVD) has lines bunched together at the top and bottom of the screen.
These lines appear on every input the TV has. Has anyone experienced this type of problem before?
Thanks
Open up the TV and unplug and re-plug the connectors to the circuit boards. This is most often caused by a poor connection of the circuit board connectors.
Posted on Mar 25, 2017
SOURCE: Blue/black vertical line in the middle of screen
Sounds like a bad connection on a ribbon cable or plug comming or going to the LCD display. This is something you should not try to fix as these circuits are very very fradgile and you can easily break or tear a ribbon cable . Call the manufacturer to get a tech to assit you. Good Luck
Posted on Aug 06, 2006
SOURCE: Green verical line on Samsung LN-S4092D TFT-LCD Telvision
the line is a panel failure. its not fixable
Posted on Dec 07, 2008
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
SOURCE: my samsung plasma has horizontal line across middle of picture
loose wire check connections
Posted on Sep 19, 2009
SOURCE: I have a ln-s3238d that i got a couple years ago.
Hi andrew, its not a big problem.. Decent TV. but the pixels are DEAD. that means you have to recover them by fixing the LCD. this would cost you around £40-60 for a 32 inch TV. hope this helps!
Posted on Nov 05, 2010
Aug 15, 2013 | Televison & Video
Jan 23, 2013 | Samsung LN-S4692D 46 in. LCD HDTV
Nov 26, 2011 | Samsung LN-S4092D 40 in. LCD HDTV
Mar 08, 2011 | Samsung LN-S4092D 40 in. LCD HDTV
Dec 22, 2009 | Samsung LN-S4051D 40 in. LCD Television
Jul 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Mar 10, 2009 | Samsung LN-S4092D 40 in. LCD HDTV
Dec 07, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Dec 13, 2007 | Samsung LN-S4051D 40 in. LCD Television
Jan 11, 2007 | Samsung LN-S4092D 40 in. LCD HDTV
81 people viewed this question
SAME PROBLEM, JUST OUT OF WARRANTY, TOOK IT IN FOR REPAIR
TECHNICIANS SAID THEY SEE A LOT OF SAMSUNG LCD'S AND PLASMAS.
WILL POST WHAT THE TECH'S SAID IS WRONG WITH IT
