Question about Kenmore Refrigerators
106.55529400 stopped making ice. red light flashing inside freezer
the dr
  • 447 Answers
SOURCE: Ice maker not making ice.
These Icemakers have plastic gears on the modules that are breaking, also some have thermostats that are malfunctioning. I recommend haveing an experianced tech look at the unit to see if you need the new upgraded indoor ice maker.
Posted on Jan 15, 2008
  • 236 Answers
SOURCE: Red light blinking inside freezer
The light may be telling you that the temperature is not cold enough to operate the icemaker.
You may have a bad defrost timer, heater or thermostat. If you have an ice bucket then it may ot be seated properly.
Stargazer
Posted on Mar 16, 2008
lsteward68
  • 331 Answers
SOURCE: Flashing red light on ice maker control unit inside freezer
I understand the price seems pretty high have you tried an OEM for a better price. I am understanding that your filter is a common filter 4396510 I think is the aftermarket number
Posted on Apr 21, 2009
SOURCE: Freezer side tmp flashes/makes noise/inside back panel iced
The freezer side is off. The temp is flashing on the meter in front of the refrigerator. This is a Samsung RS2545SH. Does this freezer have a reset button or what shall I do.
Posted on Feb 01, 2010
SOURCE: ice maker stop making ice red light flashing
http://www.dryerpartsonline.com/4389102-Icemaker-Optics-Control-Board_p_626.html
Posted on Mar 24, 2010
57029 Side by Side Refrigerator: ice maker not making ice and red light inside the ...
Your ice maker may be turned off. The blinking light is the sensor. The switch is right beside it. Is it in the on position?
May 16, 2010 | Kenmore 57029 Side by Side Refrigerator
The ice maker has stopped working. The light inside is flashing red. I checked the manual and nothing is stated about the red light flashing in the troubleshooting section. I've checked the lines and...
this sounds like a control board circuit problem..but first remove perishables and defrost freezer ..turn off or un plug..leave refr door closed..freezer door open..if you have lots of water while defrosting you almost cirtainly have froozen the evap coils solid..freezer cannot work like this..after defrost..plug in and see if temperature returns to normal..if it does it won't last indefinately..your probably have a bad defrost timer and/or evap heater gone bad
Apr 22, 2010 | Refrigerators
Ice maker stop making ice red light flashing inside freezer water dispenser still works kitchenaid kscs25
the emitter/receiver has gone bad and will need to be changed out. the part number is 4389102 at about 130.00
Feb 28, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stopped working, red light is flashing, however water is working? What is the problem, how do I fix?
For the red light try removing or replacing your filter.
The ice maker usually has a make ice bar about it inside the freezer. The down position is usually on.
Dec 02, 2009 | Kenmore 23.1 cu. ft. Side-By-Side Counter...
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side Ice maker has quite making ice
Open the freezer door and on the right side , make dure the slide is in the on position . If the red light flashes twice , then pauses , flashes twice , pauses , consistently , then close the flap door on the left side of the freezer . The light should go off . If these tests work , then the cut-off optics are good , and the icemaker needs replaced , due to the cubes not dumping . Also check the coils under the front of the refrig , to make sure they are clean of dust , lint , etc.
Sep 15, 2009 | Whirlpool GS6NBEXR Side by Side...
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
Apr 15, 2009 | Refrigerators
Not making ice flashing light in freezer door 106.53659300
There is a board for sale on eBay for $68.00.
This is a relatively easy procedure. Just have to buy the board
Mar 25, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Jan 14, 2008 | Kenmore 21.7 cu. ft. Top Freezer...
Refrigerators Logo
134 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
