Question about Hannspree Computers & Internet
Come accedo al menu segreto di hannspree sgh1113
2 Suggested Answers
SOURCE:
terryskelly
  • 9773 Answers
SOURCE: menu segreto hannspree hsg1113
http://translate.google.com
Secret service menu Hannspree HSG1113
https://electronicshelponline.blogspot.com/2015/03/hannspree-lcd-tv-how-to-enter-service.html
Possible menu - Quoting from link above:
SERVICE MODE [Hanspree AT06 42" LCD TV] (Horizontal Frequency 31.5KHz to 48KHz)
* In the TV mode, adjust volume to Zero and press number keys 9 > 8 > 7 > 6 to enter service mode.
* To exit, press the EXIT button on the remote control.
SERVICE MODE (Hanhspree GT02 32E - GT03-37E1)
1 Switch on the LCD TV .
2 Press 9-9-1 on the remote control to enter the internal Service menu.
3 Press MENU to switch the service mode pages.
4 Press ?? to scroll through the various menu options.
5 Press ?? to change the menu settings.
6 Press MENUto save the new settings and switch to next page and press EXITto exit from service mode to normal mode.
TV / AV / S-VIDEO / WHITE BALANCE / BRIGHTNESS & CONTRAST ADJUSTMENTS
WHITE BALANCE ADJUSTMENT
1 Press 991 on the remote control to enter the internal Service menu.
2 Press MENU to switch to the PW106 Scaler Menu page
3 Press ?? to scroll to Page 2-3 options
4 Press ??
to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings.
5 Press EXIT to save the new settings and exit. [Don't adjust others setting in page 2-3]
Click on the Pictures to Zoom In
BRIGHTNESS ADJUSTMENT
1 Repeat the above mentioned step 1 to 2
2 Press ?? to scroll to PW106 FE VDC Menu Page 2-1 options
3 Press ?? adjust the Brightness setting.
4 Press ?? to scroll to TV/AV/S Parameter=AV1 setting and pressuto run the setting. (This procedure will copy the settings of AV1 to S & TV)
ATSC DTV WHITE BALANCE / BRIGHTNESS / CONTRAST ADJUSTMENT
2 Press ?? to scroll to PW106 Scaler Menu Page 2-3 options
3 Press ?,? to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings
4 Press to save the new settings and exit. [Don't adjust others settings in page 2-3]
YCbCr & YpbPr of COMPONENT 1, 2 WHITE BALANCE/BRIGHTNESS/CONTRAST ADJUSTMENT
Getting COMPONENT-1 connect to 1080i signal. (The settings could not be saved if signals input from COMPONENT 2 or connect to other sources such as 720P, 480P, 480i,etc.
WHITE BALANCE ADJUSTMENT OF Component
1] Repeat the above mentioned step 1 to 2
2] Press ?? to scroll to PE106 FE ADC page 2-3 options
3] Press ?? to adjust the Offset Red and Off Blue settings.
4] Press ??to adjust the Offset Green setting.
5] Press ?? to adjust the Gain Green setting.
6] Press ?? to scroll to 480i/480P/720P Parameter=1080i setting and press ? to run the setting. (This procedure will copy the setting of 1080i to 480i/480P/720P)
7] Press EXIT to save the new settings and exit.
WHITE BALANCE ADJUSTMENT OF PC INPUT
1.Connecting to VGA Timing mode
2.Under service mode, Press ?? to scroll to PE106 FE ADC page 2-2 options
3.Press ?? to adjust the Offset Red, Offset Green and Off Blue settings.
4.Press ??
to adjust the Gain Red and Gain Blue settings.
5.Press EXIT to save the new settings and exit.
Posted on May 14, 2018
Menu segreto hannspree hsg1113
4 Press ??
4.Press ??
May 14, 2018 | Hannspree Televison & Video
AIUTATEMI!!!! NON RIESCO A COLLEGARE INTERNET
Nintendo DSi / DS / Ds XL si connette a Internet tramite connessione wireless. ? necessario conoscere le impostazioni del router. Sono elencati di seguito i passi su come si intende accedere al router e ottenere le informazioni necessarie per voi da collegare.
Come accedere al router:
1. ? necessario conoscere il ipaddress del router. ? possibile fare riferimento al manuale o controllare il gateway predefinito del computer (Assicurarsi di collegare il computer al router tramite un cavo Ethernet per voi per ottenere il gateway predefinito). Fare clic su Start poi Esegui. CMD tipo sul piccolo riquadro in basso a sinistra dello schermo. Tipo IPCONFIG nella finestra nera e ottenere il valore della vostra gateway predefinito (che inizia con 192.168.xx)
2. Aprire un browser, digitare il gateway predefinito sulla barra degli indirizzi del vostro browser. Vi chieder? un nome utente e password. (Consultare il manuale del vostro router o inserire un messaggio in modo che io in grado di fornire il nome utente e la password del router)
3. Vai alla pagina delle impostazioni wireless del router. Cercare il SSID o il nome di rete e theNetwork chiave o passphrase. Si pu? personalizzare in modo che si pu? facilmente ricordare i dettagli.
4. Assicurati di collegare al proprio SSID e inserire la chiave di rete per renderlo sicuro.
Ora che sappiamo gi? le impostazioni del router poi il suo momento di collegare il Dsi alla rete.
1. Vai alla Nintendo Wi-Fi Impostazioni di connessione del Gioco
2. Ricerca di un Access Point (SSID)
3. Seleziona la tua rete (SSID), Se si dispone di una rete aperta, basta cliccare su "OK" e dovrebbe funzionare bene! Se si tratta di un lucchetto rosso, sar? chiesto di specificare una chiave di password o di rete. Questo ? il motivo per cui reson accedere al router.
4. Verificare la connessione.
Sep 03, 2011 | Nintendo DSi XL Burgundy
RIMPICCIOLIMENTO DELL' IMMAGINE
Vai al menu della televisione e
cambiato la visione di immagini
a volte cambia da sola in questo modello
Indossare che si pensa
Jan 03, 2011 | JVC HD-61Z886 61" Rear Projection HDTV
Ho perso l'albero che va montato al centro del robot sul quale si appoggiano poi i dischi per tagliare...dove lo posso trovare? IL modello e MASTERCHEF 65 ELECTRONIC...
Ciao Matteo.
Le opzioni per aquistare un ricambio Moulinex sono contattare il piu vicino centro di assistenza Moulinex, o chiamare direttamente Moulinex, al numer che trovi sul manuale.
In questa pagina una lista dei centri di assistenza Moulinex divisi per regione. Clicca sul link al lato e scorri giu la pagina: Centri Assistenza Moulinex in Italia.
Il contatto e la lista dei centri di assistenza sono disponibili anche sulla pagina servizi del sito Moulinex. Clicca qui per aprire il sito Moulinex Italia.
Se non vivi in Italia usa come riferimento il sito Moulinex relativo alla tua nazione di residenza.
Per favore non dimenticarti di lasciarci il tuo voto.
Buona fortuna.
Ginko.
May 08, 2010 | Moulinex DG6 Food Processor
Conpatibilità con il nuovo notbook
Ciao.
Questa stampante e' compatibile con Vista e Windows 7.
Prima di connettere la stampante al nuovo computer ci sara' bisogno di scaricare i driver dal sito Canon:
PIXMA iP2000.
Scegli la tua versione di Windows dove dice "Select OS" nella pagina Canon qui' sopra.
In bocca al lupo.
Ginko.
Mar 13, 2010 | Canon PIXMA iP2000 InkJet Printer
Need to delete adobe reader 7.0.9.msi
vada al vostro quadro di controllo del menu di inizio… allora… prescelto aggiungono rimuovono i programmi quando quella finestra schiocca in su individua l'adobe e prescelto disinstalli Robert Richieda prego un momento per valutare i ringraziamenti di questa soluzione
Jan 24, 2009 | Tiny Computers B1996 19" CRT Monitor
No tengo el usuario ni el pass del router para abrir puertos
Hola Angela,
si eres abonada de Telefónica es fácil accediendo a la siguiente dirección: www.telefonicaonline.com/portalalejandra.
Simplemente te pedirá el Nº de teléfono. Ahí podrás configurar tus puertos, contraseñas, correo, etc.
Espero que te sirva la solución.
Un saludo,
FRANK
Para cualquier duda: francisco.cota@telefonica.net
Sep 21, 2008 | Zyxel P660HW-D1 Router
Computers & Internet Logo
74 people viewed this question
Top Hannspree Computers & Internet Experts
 Mike M
Mike M
Steve Allison
Steve Allison
DBurstiner
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
