All info(model# ect.) weathered off of unit. Need motor for blower. Looks like 4 ton. how many horse power?
  • 30 Answers
1/4 horsepower, 1075 RPM, 3 speed motor with a 1/2" diameter shaft will do the trick. If you have gas heating, you will need the 115 volt motor., If you have electric heating, you will need the 208/230 volt motor.
Posted on Aug 02, 2009
I have a 50zh-060-301 heat pump what horse power for blower motor and how many tons is the unit
http://dms.hvacpartners.com/docs/1009/public/0d/50zh-5pd.pdf This might help
Feb 20, 2016 | Heating & Cooling
I need exact replacement ac air handler Weather King model RCBA4882GH21...4 ton 10 kw elec heat with the I need to replace my Weather King ac air handler unit...4 ton, W shape evap coil ,elec...
What's wrong with your current AHU? Any Ruud dealer can assist you. Most 4 ton units work with r-22 or 410a. As a side note, most parts in an air handler can be replaced unless the case is rusted thru.
Sep 24, 2013 | Rheem Air Handler 4 Ton With Rhplhm Series
Trying to get info (tonnage seer rating) on a weatherking mod# 10ajb48a01 condencing unit to find a matching evaporator coil and cannot find anything on internet
This is a 4 ton model condensing unit. You can go up 1/2 ton for the evaporator, meaning a 4 1/2 (A) coil will work just fine and allow a bit more cooling capacity.
Sep 10, 2011 | Weather King 12AJA4801AH Air Conditioner
What is the HP rating if a 3 ton air conditioner?
Hi, this depends on the compressor that is installed in this unit. It may be a Copeland scroll, a Tecumseh, its hard to say. Most compressors are around 2 hp for a 3 ton unit. On the data plate it will tell you the h.p. of the blower and condenser fan motors such as 1/4 h.p., or 1/3. If you can get the name and model numbers from the top of your compressor, you can call a a/c, Refrigeration parts house, wholesale and they will have it in there manuals. The B.T.U. rating for your compressor is 36,000. There are 12,000 BTU's per ton of cooling, this is something that almost no one knows, but now you do. If it were a smaller unit such as a 2 and 1/2 ton, it would be 30,000 B.T.U.'s. You can look at the model number of a unit and you will see numbers like this, 024, 2-ton, 030, 21/2 ton, and 036 a 3 ton unit and so on. Your compressor alone will be in the range of a 2 horse unit, which ever the brand of compressor they installed in it. Please don't forget to rate me on this as I know you will be kind. I will be here if you ever need help on repairs or trouble-shooting your unit in the future, just use my user name below.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 04, 2010 | Heating & Cooling
Need a part number for fan motor on UAMB-036JAZ
Hi, what you need to do is gain access to the motor its self. If it is the condenser fan motor or the blower motor . This is a 3 ton unit from the numbers you have given me. There are two ways you can do this. On the data plate on this Ruud unit, normally they are paper with a plastic coating on Ruuds and Rheems, and it will tell you the H.P., size like 1/3, amperage, and the R.P.M.'s. Then get all of the model number and serial number from the unit. The best way is to get the information from the motor its self. It has the voltage, amperage, name of motor, example a G.E., the part number, Horse power (H.P.) r.p.m. such as 1725, 1100, and so on. Rotation, CW or CCW. The new motor will be reversable, just change 2- leads on it. This would be your best bet, to do it this way.
please don't forget to rate me and I know you will be kind. I cant give you the numbers as they will use different motors in the same unit, and different brand names.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
May 29, 2010 | Ruud UAMB Air Conditioner
What is the blower model for the Carrier Unit FC4BNF042. My unit sounds like something is loose or flapping around the blower and up into the duct work. I believe it is the blower. I took the blower unit...
Hi, when you have a little play from side to side just shows very little bearing wear on the blower motor. In and Out play is normal. Spin the wheel to see if it is true. If the blower wheel has a lot of dirt build up on the blades it will cause it to be out of balance.If it is clean, but warped, take it to a motor repair shop along with the model and serial numbers. Call you're local wholesale a/c parts house with all of your info and they will look this up for you.The numbers that you have listed shows you have a 042 which is a 31/2 ton and 048 which is a 4 ton unit. More then likely, the wheel is out of balance and should be replaced, and they can look up the info you are requesting. Good Luck,
Shastalaker7
Nov 13, 2009 | Carrier 38BRC048 Air Conditioner
1985 chevy 1/2 ton heater not blowing what would cause this?
check fuse and switch for heater if good check power to blower motor at heater core if power remove blower motor and check housing for debris (leaves etc)and blower motor for proper turning unit may need to be lubed if hard to turn or seized if seized and oil/lube not working replace blower
Oct 31, 2009 | 1985 Chevrolet Chevy
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
Is there a list that will tell me the horse power of all air con systems
not sure on hp but 12000 btu per ton in model # CPLT036HTC EX 3 TON 42 3.5 24 2 TON ECT
Jun 09, 2009 | Heating & Cooling
Freez up at the tube going to the fan blower unit
it is either low on freon or the airflow is blocked. check your filter first. then see if the coil is dirty. saying it needs a new coil because it is freezing is an expensive guess unless he did a freon leak test.
Oct 27, 2008 | Weather King 10AJA4801AH Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
