Question about HP Color Laserjet 3550 Printer
HP Color Laser Jet 3550 Smearing Colors
Just recently my printer has begun leaving what looks like smears of color along the entire length of any printed document. It started when I replaced my Cyan toner...then things that had no blue color (specifically) our logo, started having a faint blue background. We calibrated...same problem. Yesterday I replaced my black toner and now I am getting long lines that look like ladders all along my papers. I have tried calibrating, cleaning and pulling out my hair. Any suggestions? ink smears approximately 1 inch wide and 3 inches from left side of page for the entire length of page
  • HP Master
  • 1,113 Answers
Re: HP Color Laser Jet 3550 Smearing Colors
Are you using Genuine HP cartridges?
Cause from the sounds of things, youre having cartridge problems, Cyan is faulty "blue background" replace with gen. If the black is recycled/non HP then that will be your ladder problem too., If you are in fact using HP let me know and I will tell you how to isolate your fault further ie you have a fuser or transfer belt fault.
Posted on Nov 25, 2007
0 characters
3 Points
Smearing on HP laser jet 2055dn
That sounds like a drum issue. Try replacing the toner or have you done that already? Give me a call if you ever need to replace the toner. I can beat out Staples and Office Depot. Damien @ iPrint Technologies - 818.700.7419 Dir.
Aug 28, 2014 | Printers & Copiers
Yellow smear on left side margin from top to bottom of the page. After cleaning, the smear reduced to one third and confined to the lower left corner. How do I get rid of it entirely?
What did you clean? If it was the Image Transfer Belt (the big mylar belt in the front), do it again. Print and see if the yellow is smearing again. If it is replace the yellow cartridge.
Jan 31, 2011 | HP Color Laserjet 3550 Printer
My hp Color Laserjet 3550 Printer wont print black when it is out of color ink
The 3550 won't print in any color if any of the colors are out. You'll have to replace the color ink that's empty to get it to print.
In the future, if you're just printing black and white, you can select "Print in Grayscale" from the print properties to just use the black ink cartridge, which will help the color cartridges to last longer.
May 11, 2010 | HP Color Laserjet 3550 Printer
All ink cartridges leak onto to copies
I think you need to change the tranfer belt assm.
If all the colors are smearing .
Or all of your toners are bad and leaking,
Hope this helps
Mar 28, 2009 | HP LaserJet 4650 Color Printer
Do you use original genuine cartridges or refilled ones. It sounds like you have had a leak and need to completely clean out your printer heads, rollers and perhaps do a deep claean as well. You can buy faulty cartridges and toners that have one leak, then the ink continually leaves traces as it prints. When you say callibrated, do you mean you ran print tests and setting tests. Running a print test can often help to diagnose ink issues an d narrow the results down a bit. After a thorough clean, you could try uninstalling and reinstalling unit.
Aug 11, 2007 | HP Color LaserJet 3500 Printer
Printers & Copiers Logo
748 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
