Question about Vehicle Parts & Accessories
The range on the use of my key fob for my viper 7141 has gone i have to be right next to the car for it to work, i have changed the batteries and also the spare key fob is exactly the same. I used to be able to lock / unlock it from inside the house but not anymore?
    Scholar:
  • 55 Answers
Refresh my memory cause I'm older than dirt but does your alarm have a little antenna on the windshield? No ? Yes? If yes i want you to unplug the antenna and replug it in if you can. Did you have your windshield replaced or did you put tint on where the antenna is? Both of those can drastically cut down the range.
Now if you do not have a windshield antenna you are going to have to crawl your *** under the dash and find the alarms "brain". Is that possible? If you can, i need you to look for a little black wire coming out of the brain kinda all by itself, ok, do you see it? that Pilgrim is your antenna wire and notice if it is wrapped around other wires? Or is it stretched out like you lying on the couch?? That's kinda good. What you want to do is to move that antenna wire to where it runs north and south (up and down for all you techy types) anyhow i like to even loosly secure it somewhere up in the dash and BONUS POINTS awarded if you find metal because that will act as an extension giving you even somewhat longer range which is what you want. Play around with various settings and placements because every ride is different. good luck, let me know if that does not solve the problem.
Posted on Aug 14, 2009
I have a viper 7701 remote that just stopped working. Battery is new. Do I have to re program something
If it is the OE (original equipment) key fob, meaning if it is the alarm remote control that came with the original purchase of the car it should not need reprogramming. If it is an aftermarket alarm then it may need reprogramming, more information is required to answer the question.
This is a common issue and the most common problem is that the solder joints holding the battery in the proper location. If any of these are broken the remote will not function. It can be fixed with a little solder or if your uncomfortable with doing it yourself, take it to a computer repair store (they can fix it ONLY if you have a broken solder point).
Take the key fob to the closest auto parts store (aka. autozone, o'reilly's, advance) and near the counters they have a key fob testing equipment (FREE). If the remote is working a light will blink when you push the key fob button while close to the testing equipment. If the testing light shows that the fob is working but does NOT unlock your doors, it needs reprogrammed. If the testing light doesn't blink at all, repair or replacement of the key fob is indicated.
Hope this helps and good luck!
Dec 31, 2014 | 7701V Remote for Viper Responder SST Car...
Key not operating locking
It could be dirty terminals in the key fob, also make sure the battery is the correct way round, positive facing up, hope this helps.
Mar 29, 2014 | 2000 Ford Focus
Central locking not working on 2002 ford focus changed battery in fob cant find fuse 63
The key and car might need re-synchronising after changing the battery or pressing the buttons too many times when out of range.
Put the key in the ignition and turn the key to position 2 and back four times within 6 seconds.
After a beep the car is in programming mode for the next 10 seconds.
Press any button on the remote fob to synchronising.
Jan 07, 2011 | 2002 Ford SVT Focus
I changed the battery in the alarm key and now it doesnt work at all. what did i do wrong?
Vehicle key fobs work on a continuosly and randomly changing frequency so that no ones key fob should open anyone elses cars. Whenever you press the buttons, or someone unlocks your doors, the frequency is changed. The fob and computer in the car have a few codes stored so that if you press the button too many times out of range of the car it will still know what frequency should be transmitting. However if your battery dies, or you press the button too many times while out of range, you Fob and computer will be out of sync.
Long story short you may need to have your Fob re-programmed. You may fine this info in your owners manual, but will probably have to go to the dealer.
The other issue it could be is something i have heard of a few times for the chrysler FOBs, the solder in the fob that holds the connection for the battery may have broken, which will mean your battery is not connected right. You may want to consider popping it apart and taking a look to see if the solder is cracked at all.
Dec 13, 2010 | 2006 Chrysler 300
The battery on my viper 5501 ran down. I plugged it in to recharge and now it won't work. The back-up key fob does work. how can i reset it? thanks very much.
Are you talking about the Remote LCD key fob itself? If you are then you need to replace the battery. Search on ebay. Hopefully this helps.
Jul 06, 2010 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
07 Buick Lucerne seems like I have to be right next to the car for the the remote starter to work is there a certain spot I should be aiming for? It wont start my car from inside my house let alone any...
The battery may have gone weak in your remote. The gm system will never have as far of a range of and aftermarket system, so do not expect that.
Also There is an update kit for the chevy impala I do not know if this applies to the Lucerne but I would think it will seeing as they are the same platform car. This kit is to make the range better for the Key fob system. But like I say don't get your hopes up I'm not sure It applies to your car?
Good day to you.
Oct 13, 2009 | 2006 Buick Lucerne
1994 Dodge Viper will not start after storage and battery drain.
With the battery charger connected or a jumper battery simply click the alarm key fob on and then off. This will reset the alarm and the car should start...had mine towed to find this out
Apr 07, 2009 | 1994 Dodge Viper
Key fob won't unlock or lock car VW Golf 2000
You probably caused a short circuit when you changed the light. Change fuse #14. Next time, don't turn the lights on until you are finished changing the lights.
Mar 25, 2009 | 2000 Volkswagen GTI
Viper won't remote start and arm/disarm only works sometimes
Greetings Microluv,
Simple question, have you changed the battery in your remote lately? I was having similiar issues with my remote start and it was a simple matter of changing the batteries in the remote.
I figured lets eliminate the easy stuff first. :)
Dorothy
Go Ahead. Use Us.
Jul 07, 2008 | Viper RCVGC022 Remote Control
Vehicle Parts & Accessories Logo
200 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
