Question about Kenmore Dishwashers
Our kenmore dishwasher model number 587.1414 is not cleaning the dishes
SOURCE: Kenmore 587 model dishwasher produces water but won't spray or move from bottom
top washer arm not turning
Posted on Sep 29, 2008
SOURCE: No clean dishes
DETERGENT DOOR DOES NOT OPEN DURING CYCLE?
Posted on Nov 03, 2008
tzweeb
  • 318 Answers
SOURCE: Kenmore ultra wash dishwasher model number 665.158.5090
the only way you can tell if the upper rack is not getting enough water is to turn a glass right side up in each corner. then run for 2 minutes and see if there is water in each cup.
if you still dont get water, then you have checked the pump, the only thing left is that you are not getting enough water into the unit.
start the d/w at a normal cycle, let it fill and go into the wash cycle, takes about 3 minutes, then check to see if the water level is just below the heating element. if so then it has to be the wash pump being plugged.
if not enough water then you should change the water inlet valve. some times they do get plugged but also make sure you are getting full water pressure to the unit as that could cause not enough water into unit. the faucet under sink could be at fault i have seen valve work but not let enough water in, so dont be surprised if you need a new valve.
Posted on Jan 06, 2009
  • 117 Answers
SOURCE: kenmore dishwasher not cleaning properly
Look in the inside for any screen that would be easily removed, some dishwashers have a self cleaning filter so you may not find it. I have a lot of other tips for you if your dishwasher is not cleaning so check it out.
http://tclaundryrepair.com/dishwasher
Posted on Feb 26, 2009
jonniewalker
  • 1029 Answers
SOURCE: Dishwasher does not clean dishes, soap does not fully go away
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
  • filter
  • . Detergent or Detergent Cup
    It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
    Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, My dishwasher detergent cup won't open.
    Cycle Selector Switch
    Sometimes a dishwasher's cycle selector switch is the reason why dishes are not coming completely clean. Test your selector switch to determine whether or not it has become defective. If it has, replace it.
    Posted on Mar 29, 2009
    I removed the lower spray arm and cleaned out a lot of stuff. I noticed when I screwed the sprayer arm back on medium tightness, then the arm does not move freely. Any ideas? thanks
    I just looked up your kenmore dishwasher on repairclinic.com. They give free repair help that is model number specific. You may have bent the arm assembly or the retainer is still too tight. Could be it's simply worn. The replacement is about $32. Check out the self help on this site and enter your model number. Good luck.
    Jun 16, 2015 | Kenmore Dishwashers
    The dishwasher soap in my kenmore elite dishwasher is not dissloving and as a result my dishes are not getting cleaned. any suggestions?
    Check to see if it is filling with water and not draining it right back out. Give model number so I can look for a diagram to repair. Just fixed mine as it was doing the same thing.
    Dec 06, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
    The water seems to not be hitting the top row of dishes and the dishwasher has gotten louder, end result not cleaning the dishes
    Best to chck the water pump which could be partially blocked and not sending water to the top spray feed.
    It would be helpful to have the full model number in order to identify the part numbers etc.
    Sep 22, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
    I have a Kenmore built in dishwasher. Serial Number 15989990 Model 665. My dishes are not getting clean. Lots of residue on glasses on top rack and dishes streaked. Any ideas? We thought it might be the...
    I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
    Dishwasher
    Spray Arms not Spinning
    How to Buy
    Appliance Parts Online
    A bad heating element causes many problems in dishwashers...
    Dishwasher Problems The
    Heating Element not Working
    Dishwasher Maintenance
    Dishwasher Residue and Film on Dishes
    heatman101
    Asker
    Mar 06, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
    My kenmore dishwasher model 363.1404898 is not cleaning my dishes and leaves behind food on dishes
    Check your heating element..
    A bad heating element causes many problems in dishwashers…
    Dishwasher Problems The Heating Element not Working
    heatman101
    Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
    Sep 04, 2010 | Kenmore Dishwashers
    Kenmore 17033 dishwasher will not clen dishes
    USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
    Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
    Kenmore Elite dishwasher 655.16463300 not cleaning dishes
    The inlet screen is at the bottom of the unit. Clean it out and re-try.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
    Dishes on top rack don't get clean
    The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
    1. Rinse all of the food off of the dishes before you put them in the dishwasher.
    2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
    3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
    4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
    THese things should make a huge difference.
    Good luck with this and please rate my answer. Thanks. Joe
    Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
    Dishwasher wont clean
    are the bottom dishes clean and not the top?could be the chopper broke
    Oct 21, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
    Dishes not getting clean
    brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
    Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
    Dishwashers Logo
    115 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    Fred Sops
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
