Question about AT&T 964 Corded Phone
Phone line won't hang up
Sometimes the phone will ring once and then stop. If I pick up quickly I can talk to the party on the phone but when we hang up my phone doesn't hang up and makes the alarm sound, then after awhile it stops and just hear static. The static/open line stays open for at least 30 mins or more then I get a dial tone and everything seems normal. Also the open line/static affects the DSL and causes it to not work at all.
Have a good dial tone at the NIB. This problem started about 2 months ago. I have visually checked all the jacks and have not found any loose wires or touching wires.
What could be causes my phone not to hang up. Also get static on the line when someone calls, but not usually when I call out.
    Scholar:
  • 45 Answers
I would check the DSL filters. Your phone should not interfere with the DSL. Make sure there is a filter on any line going into your phones. If there is a filter replace it and see if that works. Also, check other equipment on the line, fax, computer, credit card machine. They will need filters from the DSL too. Remove these other devices and check the line for the problem then add them back one at a time.
Posted on Apr 17, 2010
How do I conference call
You may download the user manual part 1 and part 2. The conference call instructions begin on page 51 of part 2.
Feb 20, 2013 | AT&T ATT-974 Corded Phone
How to do conference call
Depends on the phone system or service you are using. On a regular land-line you can do a 3-way call (if you have this option available to you through your service provider). To do this:
1. Call the first party.
2. Once the caller is on the line ask them to hold while to connect with the 2nd party.
3. Flash to dial tone. There may be a flash button on your phone or you may just press talk. In any case you should hear a quick "beep..beep..beep" then dial tone.
4. Now you can dial the 2nd party and click the flash (or talk) again to return to the 1st party and you both should hear the phone ringing for the 2nd party.
There's hundreds, if not thousands, of different phones, phone systems, and provider combinations that have different procedures for making conference calls. This is probably the most basic way. Hope this helps
Nov 27, 2012 | Lands Phones
How to pick up the phone when 2person call in a same time?
when your using a phone with the a button for talk and end usually you can press the talk button and it will switch lines. on other models the phone will have a button marked Flash this would be the button to use. if you are using rotary phones you quickly tap the button that hangs up the receiver this will switch to the other line.
Sep 22, 2012 | Lands Phones
For a GE ProSeries telephone Model 2-9980A S/No 00098864 corded business phone - 1 line with speaker phone. What are the directions to forward the phone to another number? And, also, how to cancel the...
Go to settings on your phone, click on the phone option, it will display different option, select call forwarding or call divert, enter the number you forwarding the call to and press ok, you are done. follow the same procedure, when you get to call forwarding, you can select to cancel as you can no longer add a number.
Take care.
Oct 14, 2010 | Cell Phones
Answering system records message after hang up
One thing to try and take note of is when the message does pick up on the "two ring" message present part do you hear on your side two full rings before the pick up?
It may be that the primary ring starts on the home side as does happen sometimes with VOIP service. If you are only hearing 1 or 1 1/2 rings before the message picks up then you might try hanging up after the second full ring thus knowing no messages are present and it should overcome your problem.
Dec 12, 2009 | Uniden Cordless Phone
Conference call
To make a Conference Call
1. While on a call, press Cnf/Trn_____.
2. Dial a [DN] (or access an outside line and
dial an external telephone number).
3. Press Cnf/Trn after the called party answers.
All parties are conferenced together.
If you added an outside line to the call, press
Cnf/Trn again before hanging up to allow
the outside parties to continue talking. (If
you do not, the call is disconnected).
Note Some types of outside lines
(“unsupervised”) do not automatically
disconnect when conferenced parties
hang up. In this case, press one of the
flashing buttons to monitor the
conference.
If the parties are still on the line, press Cnf/Trn
+ Spkr, then hang up. When no one is
on the line, press Spkr to disconnect the
lines.
Mar 19, 2009 | Toshiba DKT-2020 Corded Phone
Answers two phones at one time
get the first one and second one and talk at one time
Jan 10, 2009 | General Electric 25922GE3 Cordless Phone
Panasonic kx-tc1282jxb no hang up
Some phones answer when picked up off the charger, but with some you must press the talk button to answer. Some have a green reciever on the button. And to hang up you must press the off button or the button with the red reciever.
Feb 02, 2008 | Panasonic KX-TG6021 Cordless Phone
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
AT&T 964 Corded Phone Logo
1,071 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
