Question about Acer Computers & Internet
The LCD screen on my friends laptop ''Acer Aspire 5735'' has gone very dim. Doesnt respond to the normal brightness button. Happened all of a sudden
  • 32 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
15
Posted on Aug 01, 2009
I have acer laptop 5750G. It has a very dim light. tried to adjust the brightness but to no avail..
One thing that I can suggest to you that may save you money is to try a external monitor rather than repairing it at the moment.
Sep 26, 2015 | Acer Computers & Internet
Hi, i have an Acer Aspire 5735. Most of the screen has gone black apart from about 3 inches on the left hand side which are perfectly normal. I've connected the pc to my lcd and it works fine on there. Can...
Connect your laptop to an external monitor and I expect you will find it is displaying OK on the external screen.
Browse ebay for a replacement screen.
Dec 15, 2010 | Acer Aspire 5735 Notebook
I have Acer Aspire 5732z,and webcam not workin just black
maybe be u got the acer cd disk with your notebook when u bought that just reinstall the webcam it's simple if you don't have a software i will give u a link after don't take too much head........
Jul 31, 2010 | Acer Aspire 5735 Notebook
Acer aspire 5735 will start up however there is no picture on screen
Try to connect your laptop to a external monitor/lcd screen if it will display this will prove that the problem might be on the flex cable from your lcd to the board or might be an inverter problem.
Jul 24, 2010 | Acer Aspire 5735 Notebook
My acer 5735 won't hold a charge. Seems to charge (green light)
if it doesnt hold a charge its degraded and will need to be replaced . people dont realise that keeping a laptop plugged in damages the battery
Jan 10, 2010 | Acer Aspire 5735 Notebook
Acer Aspire 5735 LCD changes bight-dim-bright, etc.
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 24, 2009 | Acer Aspire 5735 Notebook
Acer Aspire 5610. LCD very dim all of a sudden.
That sounds just like an inverter problems. There is a slim chance the bulb could be a problem, but I would replace the inverter. It is not too hard to do, no soldering involved.
You have to remove the screw covers on the frame of the LCD frame, and then carefully pop off the frame. The inverter should be on the bottom center of the screen.
Be careful, there is a high voltage in that little baby. Just get the full numbers, and do a search on the internet and buy yourself a new inverter to replace the old one.
Apr 08, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Lcd screen- bright is low
pls rate me FIXYA if u like my response it will help me
Mar 16, 2009 | Acer Aspire 5735 Notebook
Acer Aspire 5610 Laptop - dim screem
Holding Fn key down and press up arrow toturn up the brightness.
Nov 07, 2008 | Acer Aspire 5610-4648 Notebook
Acer 4520 light going dim
Normally the way it works is if you plug in your AC Adapter to a laptop the computer screen will Brighten up since its no longer running off of battery and is actually charging . The reason why it should go dim is when you unplug the Ac adapter it goes dim to save battery life and last longer. If you are getting a really dim you can check and make sure that the Ac adapter jack on the adapter or motherboard isnt loose and it could be having contact to the unit and be loose inside and every small movement causes it not to charge / charge in and out and would cause this Dim effect. Again this depends on how old the computer is and I dont really think its the LCD or backlight going bad but you can try to mess with the screen brightness and If im not mistaken on that model it should be the FN key and the Right > and Left < Key for lower and higher brightness. Give that a try and check the adapter connection and you can pin point the issue . Hopefully it doesnt come worst to worst which could be a bad LCD going bad or damaged lcd internal cable. Hope my answer helped guide you closer to a solution.
Aug 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
