Question about HP w1907 LCD Monitor
HP w1907 both DVI and VGA inputs are active
Both my DVI and VGA inputs are active and I'm not sure how to deactivate one or the other. It shouldn't be a big problem but whenever I put my cursor on the right side of the screen (while in VGA, which is the default) it moves onto the screen which is invisible to me. The only way to get to this other screen is to double click my menu button/hit menu and select switch video input. It may just be that this is a nuisance but I have also noticed that my fps has been lower for no reason that I can see so I'm hoping that this can fix both problems. Thanks for any tips you might be able to share!
  • HP Master
  • 2,252 Answers
Or RTM
connect the DVI and leave it be.
here it is, try reading how to use this display\
it has OSD menu bottons too that allow you to change things.
https://support.hp.com/us-en/product/hp-pavilion-19-inch-flat-panel-monitors/447429/model/3351965/manuals
Posted on Apr 19, 2017
    Habit-Forming:
    New Friend:
  • 22 Answers
Hi mate, its seems by what your saying that you have both dvi and vga cables connected to the monitor from the computer, the easiest solution is to remove the unwanted input cable from the pc and monitor ( i would remove the VGA) then restart the computer you really should only run a single cable either vga or dvi not both at once the monitor just comes with both cables encase your pc doesn't have one of the connector types, there not there to both be connected at once :)
if you have a reasonto want to keep both cables connected then you need to right click your desktop , click display settings, you should see two monitors there labeled 1 and 2
click on the phantom display ( probably number 2) then click the drop down box titled "Multiple Displays" and change the option to "disconnect this display" , then apply the changes and then your problem is solved
if you are useing a older windows like 7 or 8 the proceedure is the same but the name of the drop down box may be diffrent but it still has the same option to disable the display
below is the windows screen ( i have 3 displays so ignore number 3)
HP w1907 both DVI and VGA inputs are active - disp-ray0hjyhdiz4pf0utlyrskko-2-0.png
3 Suggested Answers
  • 40 Answers
SOURCE: No Input Signal, Monitor Going to Sleep
if you have twisted od bent the cord to much the wires could have broke inside the cord.
Posted on Jul 31, 2009
  • 31 Answers
SOURCE: Hp w1907 Monitor going to sleep
try the link provided
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00061509&cc=us&lc=en&dlc=en&product=3351967
Posted on Sep 15, 2009
Hp w1907 VGA no input signal
its is telling you the truth (99.9999999% of the time)
believe it !
no PC stated
no TV model stated nor clear connections stated.
are you trying to get the PC (the tower means that)?
to run to video concurrent ports at the same time?
so do both fail,
VGA side
and DVI side,
you never said.
hard to help lacking
what TV
what Tower
what connections, and special adapter (HDMI)
the TV has DVI??
sorry, cant see what you have there. at all.
Feb 01, 2018 | HP w1907 LCD Monitor
Hp w1907 monitor cord does not fit my hp computer is there any adaptors i can buy
Yes there are many adaptors, go to your local computer store and find the correct one.
Take note as there a number of connection types as shown below:
VGA blue connector.
DVI White connector
HDMI ususally a narrow black connector.
Thanks
damnor01
Mar 21, 2011 | HP w1907 LCD Monitor
HP W2007monitor VGA No Input Signal DVI No Input Signal Going to sleep
try HDMI? also switch ports on video card in case there are 2
Mar 01, 2011 | HP w1907 LCD Monitor
No vga input/dvi input monitor going to sleep. irksome! can somebody give the appropriate solution. tns.
When i turn my computer on my monitor keeps saying no vga input and no dvi input then the monitor says going to sleep ..........PLEASE HELP ME!!!
Feb 10, 2011 | HP w1907 LCD Monitor
My hp monitor flashes no dvi imput signal
First, make sure the dvi cable is hooked properly to the computer and that the computer's VGA card's dvi output is set to work in the monitor's advance options.
Has this computer/monitor combinatioin ever worked before? Or did the message appear after successful operation of dvi to the monitor?
Perhaps, try to use a vga cable to the lcd monitor to see if that input works.
Good luck on this repair.
Jan 28, 2011 | HP w1907 LCD Monitor
Monitor wont come out of sleep mode
I'm guessing you are using a the VGA input of this monitor (the smaller "D" shaped connector with 15 pins) on the back. If not, and you are using the DVI input (larger white connector), then check your PC video output. I've seen this occur with HP monitors when they accidentally get set to "digital" input. Its easy to set that way (even by mistake), but not as easy to reset to analog (VGA). To do that, you'll need to find someone with a DVI output on their video card. Once you connect to a DVI source, the monitir will come on and stay on. You then need to go into the menues of the monitor, find the setting and change it back to "analog". After you do of course, you won't get an image on your monitor until you reconnect to an "analog" (VGA) source.
Jun 02, 2010 | HP w1907 LCD Monitor
My VGA signal is active but I have no DVI signal.
You must just have one port to be active.
Let's say you want to use the VGA then it should only be the one plugged-in and vice versa
you can't have both ports to be connected at the same time.
Feb 28, 2010 | HP Computers & Internet
Jul 31, 2009 | HP w1907 LCD Monitor
HP w1907 LCD Monitor Logo
83 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
