Question about Hampton Bay Dryers
Model#666834 speed switch wires fell off switch. Need location of wires on switch? L,1,2,3, white,black,yellow,blue.
Blue wire came off for the light and i would like to know which set it connects to. when i put it back with the blue wires , the fan controls the light. please help.
Posted on Aug 02, 2009
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1983 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1983
STEREO WIRING COLOR CHART:
Constant 12V+: White/Blue
Switched 12V+: Yellow/Red
Illumination: n/a
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers: 5 1/4" Side Panels
Left Front (+) Blue
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6 1/2" Rear Doors
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/Black
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1388
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 01, 2010 | Honda Civic Cars & Trucks
Stereo wiring- what colors are wat?
1992 Honda Accord Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: White/Yellow
Radio Switched 12V+ Wire: Yellow/Red
Radio Ground Wire: Black
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Yellow/White
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2?
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/Green
Left Front Speaker Wire (-): Gray/Black
Right Front Speaker Wire (+): Red/Green
Right Front Speaker Wire (-): Brown/Black
Rear Speakers Size: 6 1/2?
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Blue/Yellow
Left Rear Speaker Wire (-): Gray/White
Right Rear Speaker Wire (+): Red/Yellow
Right Rear Speaker Wire (-): Brown/White
Dec 22, 2010 | 1992 Honda Accord
I need diagram of the stereo wires to put in an aftermarket stereo
1996 Honda Accord Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow/White
Car Radio Accessory Switched 12v+ Wire: White/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow/White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
Nov 24, 2009 | 1996 Honda Accord
What are the stereo color codes for a 2002 jaguar x type 2.5.. hooking up amp with the factory deck and dont wanna buy the iso harness thaNKS
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|red/grn & red/org |+ |ignition harness |
| STARTER|gry/blk or lt. blue |+ |ignition harness |
| IGNITION|green/black |+ |ignition harness |
| SECOND IGNITION|pink/white |+ |ignition harness |
| THIRD IGNITION|red/wht (key sense)|+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| SECOND ACCESSORY|pink/yellow |+ |ignition harness |
| POWER LOCK|black/blue |- |DDM *1 |
| POWER UNLOCK|black/white *2 |- |DDM *1 |
| LOCK MOTOR|yellow/black | |DDM *1 |
| UNLOCK MOTOR|white/purple | |DDM *1 |
| DISARM DEFEAT|white/green | |pass. kick, harness to rear |
| PARKING LIGHTS +|use neg. wire only | | |
| PARKING LIGHTS -|white/green *3 | |headlight switch |
| HEADLIGHTS|white/green *3 |*3 |headlight switch |
| DOOR TRIGGER|black/white *4 |- |underdash light |
| DOME SUPERVISION|comes on w/unlock | | |
| TRUNK/HATCH PIN|white/black |- |REM *5 |
|TRNK/HTCH RELEASE|black/blue |- |release switch or REM *5 |
| FCTRY ALARM ARM|arms w/ lock | | |
|FCTRY ALRM DISARM|disarms w/ unlock | | |
| TACHOMETER|brown or brn/stripe | |main harness pass. firewall |
| SPEED SENSE| | | |
| BRAKE WIRE|org/yel or org/blu |+ |brake pedal switch |
| HORN TRIGGER|gray/orange |- |FEM *5 |
| WIPERS|red/blk(L),red/grn(H|+ |wiper motor |
| LF WINDOW UP/DN|white - yellow |A |DDM *1 |
| RF WINDOW UP/DN|wht/pur - yel/pur |A |FEM *5 |
| LR WINDOW UP/DN|blu/red - pur/blu |A |REM *5 |
| RR WINDOW UP/DN|blu/orn - pur/wht |A |REM *5 |
| RADIO 12V|orange/black |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow/green |+ |radio |
Notes:
NOTE: This vehicle is equipped with a passive immobilizer that needs to be bypassed for remote start operation only. Use DEI part number 555U to bypass. *1 The DDM (drivers door module) is located in the center of the drivers door. *2 Requires a double pulse to unlock. *3 Parking lights require a negative trigger with a 1800 ohm resistor in-line to the white/green wire. Using a negative trigger with a 780 ohm resistor in-line to the same white/green wire will turn on the headlights as well as the parking lights. *4 This wire may cause the aftermarket alarm to false when the vehicles electrical system shuts down. Use a relay to isolate it. *5 The FEM (Front Electronic Module) is located in the drivers kick panel. The REM (Rear Electronic Module) is located in the trunk, just above the battery. hope that helps
Sep 27, 2009 | Car Audio & Video
I need the diagram for the audio cables
do u mean the radio connector? if so here it is.
Radio Constant 12V+ Wire: Blue/White
Radio Dimmer Wire: n/a
Front Speaker Size and Location: 6 1/2′ Doors
Rear Speaker Size and Location: 6′ x 9′ Rear Deck
Sep 16, 2009 | 1997 Honda Civic
1991 honda accord radio wires cut need schematic
Radio Constant 12V+: Blue/White
Radio Switched 12V+: Yellow/Red
Radio Ground: Black
Radio Illumination: Red/Black
Radio Dimmer: n/a
Radio Antenna: Driver’s Pillar
Front Speakers Size and Locations: 5 1/4′ Doors
Left Front (+): Blue/Green
Left Front (-): Gray/Black
Right Front (+): Red/Green
Right Front (-): Brown/Black
Rear Speakers Size and Locations: 6 1/2′ Side Panels
Left Rear (+): Blue/Yellow
Left Rear (-): Gray/White
Right Rear (+): Red/Yellow
Right Rear (-): Brown/White
May 12, 2009 | 1991 Honda Accord
I need to find out which stereo wires are the positive and which are the negatives?
Here is the complete discription of what each wire color does. Please rate this info.
1991 Honda Accord Car Stereo Radio Wiring Diagram
Front Speakers Size: 6 1/2′
Mar 10, 2009 | 1991 Honda Accord
Wiring the replacement 3 speed switch (fan motor)
I called King of Fans and the rep that I spoke with gave me the correct wiring for the 3 speed switch:
L White
1 Yellow
2 Blue
3 Black
The problem is that after I wired it this way I am getting the same result (off on 3 settings and a motor hum on 1 setting). So, either the Westinghouse switch that I bought at Home Depot is not compatible or it is the capacitor. The saga continues.
Feb 18, 2009 | Hampton Bay 44 In. White Carousel II with...
Hampton bay ceiling fan
we have a hampton bay fan burning smell coming in didnot run
May 14, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
76 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
