Question about Samsung Computers & Internet
I have a samsung STM330 tablet it has charged but won`t turn on.
I have tried all the button combos and nothing. I have taken the back off and disconnected the battery and reconnected it -still no joy it won`t turn on.I have plugged it in with original charger, the unit gets warm but still won`t turn on! any ideas?
    Top Expert:
  • Samsung Master
  • 52,781 Answers
  • Defective battery
  • Defective charger
  • Defective power switch
Posted on May 13, 2018
SOURCE:
  • 1894 Answers
SOURCE: Cannot get past opening screen or turn off unit. Unit seems frozen
try to restore the factory settings.. this may help
Posted on Jan 12, 2008
  • 489 Answers
SOURCE: Samsung Alias will not charge.
try with another battery. if it charge you have battery problem. if it doesnt you have motherboard problem with phone
Posted on May 30, 2009
myrlex
  • 674 Answers
SOURCE: Toshiba Equium laptop not powering up.....dead!
hardware problem chech the board.. maybe the regulator is damage.. need to change.. if you can't do just bring to certified laptop technican.. to fix your unit
Posted on Jun 11, 2009
  • 32 Answers
SOURCE: batteries are charged disconnected and used seperate charger thet had 3/4 charge to start with push start button nothing wheels locked but when charger is plugged in controller lights light up showing
it sounds like dead cel in one of the batteries, try having batteries loaded tested.
Posted on Jul 13, 2009
  • 6705 Answers
SOURCE: i have an ematic tablet model:EGQ307 when i plug in the charger nothing happens when i try turning it on still nothing do you have any idea how to fix this?
Try to fine out what is defect the charger, the cable, or the tablet, by testing other cable, charger and tablet. not all 3 the same time, but one at the time.
Posted on Jul 13, 2014
Why will it not turn on
try taking out the battery and unplugging the power cord from it and then holding down the power button for the count of 5 the long way 1 one thousand two one thousand ect.... this will drain back the power from the board and it just might boot after you plug everything back in again and try to power it back on
Mar 06, 2015 | Acer TravelMate Computers & Internet
My acer travelmate will not turn on
Remove the battery, and unplug the computer. Hold down the power button for 60 seconds. Plug the computer in and try restarting. If this works, turn off the computer and reinstall the battery. You probably have a dead battery.
If this does not work, you may have a motherboard issue.
Feb 13, 2015 | Acer Computers & Internet
Sony vaio desktop
disconnect the adapter+battery and HOLD the power button by 30 seconds this remove any EDS. and then reconnect again, and try again.
If this doesnot resolve the problem, clean the contacts ram, in the male and female contacts with contacts cleaner.
God bless you
May 22, 2013 | Computers & Internet
'91 LS400, trunk will not open. key will not turn, electric latch switch clicks but won't open. valet lock in open position. Tried 1) disconnect battery, reconnect battery, use switch, push down on...
If you hear the sound of the electric latch switch, then it's working but stuck somehow. Just put the key in the switch and turn it to the right and then pull up the trunk or ask someone to help you. it will open. I tried it today and it opened with me. It was stuck from inside by some kind of a broken plastic pieces. Just removed it and now it's working fine. good luck
May 26, 2011 | 1991 Lexus LS 400
I am getting a beeping then E1 error code on my dishwasher then nothing else happens. Thanx for any help anyone can give
Try disconnecting power for at least 30 seconds [not just the off button] and reconnect. If no joy, then you need a trained repair man
May 25, 2011 | Dishwashers
Compaq laptop will not power up
try taking the battery out, make sure the ac adaptor is not connected, hold down the power button for 60 secs and then put the battery back in and try turning it on.
Sep 14, 2009 | HP Pavilion dv6000z Notebook
Central locking stopped working on my corolla verso '06. any idea why?batteries are fine in key and reciever isn't covered by anything!please help!
TWO THINGS TO TRY... FIRST DISCONNECT BATTERY. LEAVE DISCONNECTED FOR TWENTY MINUTES, WHILE DISCONNECTED TURN THE IGNITION KEY TO THE RUN POSITION AND LET SIT...AFTER 20 MINUTES TURN KEY OFF RECONNECT BATTERY.. THEN TRY IF STILL NOTHING, THEN TRY TURNING KEY TO THE RUN POSITION AND LEAVE FOR 10 MINUTES.. THEN TRY IF STILL NO THEN GET BACK WITH ME FOR FURTHER INFO
Sep 01, 2009 | 2006 Toyota Corolla
WHEN I PRESS POWER BUTTON NOTHING HAPPENS
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. GOOD Luck.!!
Aug 27, 2009 | Insignia D400a PC Desktop
It won't turn on again
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 10, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Open Questions:
Usa/Helpline-{80.0}-{47.4}-{94.12} Samsung printer Tech Support phone Number Samsung printer Tech Support Number for Samsung printer Support 1{800-474}-{9412} In present day time use of web has occurred in a wide range and the life of a human is Samsung printer 10s work with both Mac and PC PCs, and they can be associated with the two sorts of PCs in a similar manner. Samsung printer Support Phone Number. Around the world, Samsung printer produce All-In-One with basic printinG copying and scanning functions. Samsung printer are compact and lightweight.Samsung printer Tech Support Number 1800 474-9412 is an independently owned and operated all kind of technical support. There are a long series of Samsung printer including latest technology and affordable price. Samsung printer are the most utilized and regarded for their consistent quality and consistency. Around the world, Samsung printer are the most utilized and regarded for their dauntlessness and consistency. Samsung printer specialized help Numbergrnsrg grnsrbre sgbebe g Samsung printer organizations guarantees the best response for the customers. kro jeet ki tayari aa rahi h bjp ki swari Our specialization in catering to the neGeds of the Samsung printer users makes us the most reliable Technical Support providers for Samsung printer 10. Customers may face different levels of technical issues while operating the Samsung printer devices, our core team for Samsung printer tech support phone number professionals is specialized in handling any level of the technical inquiry
Jul 16, 2019 | Samsung Computers & Internet
Computers & Internet Logo
91 people viewed this question
Top Samsung Computers & Internet Experts
asber
RONALD CARTER JR
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
