Question about Kenmore Elite Oasis 27052 Top Load Washer
Will not power up. Checked outlet and it is energized
  • 11,896 Answers
Power Supply On Unit will need replacement
Posted on Aug 01, 2009
Power outlets suddenly stopped working
Did you check 30 amp power outlet fuse? Also, check the power outlet relay, the fuse won't go hot unless the relay is energized.
Apr 10, 2016 | 2006 Kia Sorento
How to test the electrical system of the generator for free
Ez test to determine if stator wiring is ok. This test works on generators that have two sets of 115v plugs and 220v plug. Use a 12v, 1amp ac power supply ( smaller ac power supply should work ok ). With generator not running, apply 12v to one of the 115v outlet plugs. Now verify 12v output voltage with meter at another 115v outlet on generator. Also verify that there is about twice the voltage at the 220 v outlet plug (should be about 20v - 24v) . If the adjoining 115 v outlet plug has no output or very little voltage or if the 220 volt plug has no output, most likely stator is damaged or breaker is off. If the stator is shorted voltage reading will be very low and power supply will heat up. If stator is open, there will be no voltage at second 115v plug or 220 v plug. If voltage is ok at the other outlet plugs as per test above then most likely problem is with voltage regulator, or brushes not making contact or armature winding open or just needs to be energized. Unplug the 12v power supply after test to prevent it from overheating. Most generators have two 115v windings that together power the 220v plug. When you energize one of the windings with the 12v power supply, the second 115v winding will be energized also and give you a voltage reading about equal to 12v. You will not damage the generator with this small voltage being input thru the plug. Good luck
Oct 14, 2014 | Electrical Supplies
My mackie swa 1501 when you plug in no power checked the outlet their is power checked power cord good. what can i do
There are many possibilities, the switch, motherboard, electronics etc. If you are a DIY kind of person and you want to try trouble shooting yourself, you need tools. Better still, take it to a service person/ outlet to proper checks.
Oct 06, 2014 | Mackie SWA1501 Subwoofer
UPS backup problem
Hi Shrichandra,
Make sure that the battery you are using from the APC UPS is the correct one for the EnerG UPS, just because it fits doesn't make it the right one.
If you need UPS, Surge, or Power Related help contact Daniel with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/ ** If this helped - click YES :) **
Apr 14, 2014 | Computers & Internet
NO POWER! WALL OUTLET ENERGIZED. 20AMP FUSE GOOD. HELP
Not a solution, just a safety measure. Please keep this unit unplugged until you find a solution for safety's sake. You didn't mention the brand, but some ovens have been starting on their own while the owner is away and causing an explosion and a house fire.
Feb 14, 2013 | GE JVM1660 Microwave Oven
Monitor doesnt turn on
From your description, it sounds like the internal 5 Amp cartridge fuse is open. Will need to open the housing and inspect the fuse for failure. If located and failed, replace it and energize the monitor.
If the fuse fails immediately, you have a High Voltage power supply short and the monitor is scrap. It will cost more to replace the power supply/transformer than the monitor is worth.
Hope this provides some useful information.
-Jim
Oct 17, 2009 | ViewSonic OptiQuest Monitor
UPS does not provide output power to outlets when turned on.
Hello
I've never seen a schematic for this. It's difficult to diagnose online but I would look at the primary circuit before the inverter. Possibly one or more bad caps or the inverter itself. Good Luck
Jul 28, 2009 | Energizer ER-PRO1000 1000 VA Tower Battery...
No power to lights, air and slide out in the trailer
sounds like one leg does not have power. Could have a bad plug.
Jun 08, 2009 | Energizer Rechargable Battery with Charger
The dishwaher dose not empty even with the pump running
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Mar 01, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore Elite Oasis 27052 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
