Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
Frige warm freezer working I removed excessive ice on coils behind freezer paney No cold air coming into the frige HMM??
  • jjayvee Aug 03, 2009
    i did that. ice is gone . so far it is around 39 degrees.I cant seem to get it lower. Will see if ice builds up again. I understand it could be the defroster or the control board. How do i know which ?
    thanks for the help
  • 3,037 Answers
Is there airflow coming through the fridge? If not, then it may be a burnt out fan. All parts are purchasable from www.repairclinic.com where you could actually order all suspected parts and return the ones that don't fix the problem within 30 days. A good deal for the average person for sure, though again, first check for air flow. I would bet otherwise a thermostat problem. Let me know how this turns out.
Benjamin
Posted on Aug 03, 2009
  • 1,596 Answers
Check for ICE in Vent TO Fridge You May Need to Unplug for A Few Hours To Dislodge any ICE Blocking Vent / Vent's
Posted on Aug 01, 2009
Freezer works now and fridge still warm
your right the air is not getting through the cold coil / when you defroated it . did you remove the back of freezer . if not there is still 2 in of ice back there blocking the air flow/ now a good defrost is needed but you need to correct the problem of why this happened . either the timer / heater or defrost termminator is bad . usualy its the heater.. mm hope this helped .. feed back pls
Feb 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side builds up ice on back wall ,then both sides stop air flow
Hmm excessive moisture entering the unit - this can happen with excessive door openings or bad seal gaskets - make sure the seal is tight and not worn out. You are talking about frosting on the freezer outer wall right not behind the back panel ?
Try removing the back panel and look for icing/overfrost on the evap coils too - that could signal a defrost problem inw hich case you would need to inspect and change the control board or defrost timer components.
Sep 26, 2009 | Kenmore 53642 / 53644 Side by Side...
Freezer and frige not that cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
Whirlpool Gold freezes up to frige side
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 24, 2009 | Frigidaire FRS6R5EMB Side by Side...
Freezer is working good but the frige is 52
OR
Aug 17, 2009 | Refrigerators
Warm fridge cold freezer
Hi,advance thermostat setting, to get colder , it's possible you got defrost problem, is there excessive ice building inside back of freezer? to determine if you have a defrost problem, unplug ref. for about an hour,let it defrost, let all ice melt away, it's better to remove your produce, keep doors open to speed up defrosting, after defrosting and cleaning plug back your ref, and let it work for another hour, and check result, if it's o/k, put back your produce, let me know, during hot summer months, regular use (opening) of ref, could cause excessive ice build-up evap. if after defrosting and cleaning ref. work good for 3 to 4 days, but start doing the same thing, let me know, it means you got a defrost problem. also check your thermostat, but first defrost and clean it, that could just be your problem. good luck.
Aug 13, 2009 | Refrigerators
Blowing cold air but not cold enough to keep frige cold
if one of the panels in the fridge has frost on it, the evaporator coils may be iced up. this restricts the cold air flow. to defrost: empty the fridge and freezer, turn it off, remove the panel in the freezer that has the frost, use a hairdryer and defrost the ice buildup, sop up excess water, dry it up, replace the panel, turn it on (while it's empty), set the temp halfway, and close the doors. when the compressor turns off, fill the fridge. if the panels are frostless and the coils are warm, you may be out of refrigerant from a freon leak somewhere. it might be cheaper to replace the fridge.
Jul 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My frige stays warm all the time it is a Hotpoint
evaporator coils are iced up on the freezer side. either take everything out of the fridge and unplug it and let it sit for a day to defrost, or remove the inside rear panel where there is frost and (with the fridge off) use warm water sprayed on the ice to defrost it (or use a hair dryer, but just until the ice is melted. do not overheat the metal). soak up the excess water (underneath the fridge, too), and turn it on empty. let it run empty for a day to get it cold, then put the stuff back in. if the stuff is in there when it's warm, the humidity will ice up the coils again.
Jul 23, 2009 | Hotpoint HSS25GFP Side by Side...
Frige freezing solid
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
64 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
