Question about Haier ESA306 Air Conditioner
Water trinkling sound
When the air conditioner is running there is a sound that is similar to a running brook of water.....
  • kirkpatti196 Aug 01, 2009
    This sound is very loud and interrupting my sleep......is there anyway to get the water out?
    This sound is very loud and interrupting my sleep. Is there anyway to get the water out?
  • 158 Answers
ITS THE REFRIGERANT CIRCULATING INSIDE .NO CAUSE FOR CONCERN .IF IT IS DISTURBING YOUR SLEEP,YOU R A LIGHT SLEEPER .
Posted on Aug 04, 2009
  • 867 Answers
That is normal, if cooling good dont worry about it
Posted on Aug 01, 2009
  • bozcro
    bozcro Aug 02, 2009
    its not water, its the cooling fluid, cheap ac's do this, nothing to fix
  • 11,896 Answers
This is normal sound, it is just a condensation buildup inside the machine that is dripping into drip pin than drips outside.
  • Nate Stansfield
    Nate Stansfield Aug 01, 2009
    Check the back drain hose to make sure water is draining out and not building up in the unit.
Need wiring diagram for a single phase brook motor n a broomwade compressor
I suggest you contact Brooks if they are still in business. If not there is lots of motor info on the net.
Traditional single phase motors are fairly straightforward and similar to each other. The main thing to watch out for is to have the start and run windings wired with the same polarity. If the polarity is reversed on either winding the motor will run backwards.
Feb 06, 2016 | Air Tools & Compressors
Making clicking sound spitting water out
Water drain clogged take a flashlight & look for drain & put a coat hanger or similar wire in hole . Dust accumulates n water.
Jul 14, 2012 | Kenmore 75051 Wall/Window Air Conditioner
The driver's side of the floor gets soaking wet when I run the air conditioner. What should I do?
When the air conditioner is running, it forms condensation in the heater box, which is located under the dash board and quite difficult to access. fortunately, you don't have to get in there. The heater box has a drain tube that drains the water out of the front of the fire wall.In the engine compartment,look on the passenger side ,down low on the firewall, for the drain tube. Sometimes it's hard to see, but look closely, its probably covered with the same sound deadening as the rest of the fire wall. You may be able to stick a wire or similar item up into the tube. If not, it will take air pressure from an air blower to blow it out. You'll know when it's free when water starts coming out.
Jul 19, 2011 | 2003 Dodge Dakota Club Cab
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Unit sounds like water is flushing thru on the inside, but there is no leakage anywhere. it sounds like a babbling brook inside the unit.
it may just be the refrigerant rushing through the system or the condensate water being thrown against the outside coil by the fan blade to evaporate the water, either case is normal
Jul 10, 2010 | Frigidaire FAC124 wall/Window Air...
New air conditioner turns itself off two minutes after starting
this sounds as if you have an over amping compresser or blower motor......you'll need an amp meter to be sure. as they over amp they heat up and go off on internal protection until they cool back down in which case it may try to run again and again and again and again and again......should I continoue...good luck
Jul 08, 2010 | Sharp CVP10NC Air Conditioner
No Cooling
The water pump or the float valve is not working.
Aug 02, 2009 | Fujitronic FH-797 Portable Air Conditioner
Kenmore Air cond. model # 2539750610
hi there pat.have u checked the cap on the fan motor.us a multimeter and use the mfd function on it to see if it`s say 50uf and if you get a 20uf reading.replace the the cap.
Jun 08, 2009 | Heating & Cooling
Water leaking from portable air conditioner
Sounds like the drain line is blocked you would have to take this unit apart in order to check this. I would use a can of air to blow out the leakage. Also make sure the unit is level
Jan 23, 2008 | Heating & Cooling
Haier ESA306 Air Conditioner Logo
420 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Terry Hair
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
