Question about Bissell 1960-3 QuickSteamer Plus Upright Vacuum
I have the Quick Steamer Plus 160 Series/2070 Powerbrush. It will not release cleaning solution and will not pick up solution that had already been dispensed. Is this something simple I can fix???
  • Anonymous Mar 19, 2014
    Tank that attaches to the machine leaking at the point off connection
I checked the bottom of the fresh water supply container and all was well there then I used a pin in the tiny air valve on the container. Turned the machine on, pulled the lever to release water and held it for several minutes and finally the water started to release and the machine works fine now.
Posted on Aug 02, 2009
Replace power cord Bissell Powerforce Powerbrush
Hey Shelly! Sorry to hear the dog chewed the power cord.
You may want to contact one of our Authorized Service Centers for assistance.
Here's a quick link to locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Mar 09, 2013 | Bissell PowerForce PowerBrush Deep...
I need operating manual for vapor white wing steamer
This is from an Amazon review. I have misplaced my manual and was searching for a pdf file without any luck. I think I have it under control if I only knew where to put my distilled water.Basic operation of the WhiteWing is:
1. Fill the tank with distilled water
2. Attach the hose to the steamer.
3. Attach the extension handles and attachment you want.(Be sure to watch the video and read the instruction booklet. Some of the attachments have specific uses and setup instructions)
4. Lock the finger trigger.
5. Plug it in.
6. Turn it on.
7. Wait 20 min. or until the pressure gauge reads between 3.5-4.5.
8. Get ready to rock - press the steam release button, unlock the finger trigger and start steaming.
For many jobs such as countertops, shower stalls, stovetops, you will need to follow behind the steam, wiping with a cloth to remove the released dirt from the surface. Some jobs may require you to start with a non-toxic cleaner or grease remover such as Orange Clean or Method brand cleaners. Remember, you'll be breathing in vaporized cleaner. So be sure it's something non-toxic and non-irritating. I prefer the Method brand cleaners.
Jun 20, 2012 | Vapor WhiteWing Steamer Canister Vacuum
NO,LOOKING FOR MODEL#2070 FOR BISSELL PRO STEAMCLEANER, INSTRUCTION MANUAL
Model 2070 is listed as the Quicksteamer™ PowerBrush on the Bissell website. The User Guide for the 2070, although labelled for the 2050 is here:
http://canada.bissell.com/images/UserGuides/1950C.pdf
If this does not match with your model suggest you try browsing or searching the Bissell site to see if you can find a closer match.
Mar 24, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
How can determine when it's time to replace the drive belt on my Bissel Power Steamer? Is there a certain number of hours of usage that I need to keep track of or does the belt replacement depend on the...
Usually, replacement is needed when the brush no longer runs or is intermittent. Check the brush bearings and for debris build-up whenever the belt is changed. Good luck!
Jun 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Powersteamer 1697, 8804 series, Smartmix will not despense cleaning solution
there is usually a button or release lever by the handle that u sqeeze to release salution
Jan 22, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell Power Steamer Proheat Plus not dispensing
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dfsghs
Jul 07, 2009 | Bissell 1698-1 PowerSteamer ProHeat Plus...
How do i put belts on a bissell powerbrush steam cleaner?
If this is the model i'm thinking of. Make sure the units unplugged from the wall. There should be about six phillips head screws to remove. The motor should now be exposed. This is a good time to clean up the inside of the unit. Use liquid wrench or WD-40 and lubricate any moving parts. Make sure the brush is in good shape some require you to rotate or flip the brush to even out the wear. I hope this has been helpful.... : )
May 07, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Proceedure?
You release the water on the reverse stroke, and the machine will pick up in that same stroke. You push the machine forward to position it and pull back slowly as you pull the trigger to release solution and clean the carpet.
Feb 01, 2008 | Regina RG3100 Vacuum
Emptying the powerbrush
Gently
press the Quick Release tabs on the Clean/Solution Tank
and slide the tank off of the unit.
Grab the Dirty/Collection Tank and pull to remove.
While at the sink, remove the Tank Cap by turning
approximately 1/4 turn counterclockwise and lift
out the cap.
Empty the tank. Rinse the Dirty/Collection tank with
warm water.
Replace cap and turn approximately 1/4 turn clockwise,
until snug.
Slide the Dirty/Collection Tank into the unit. Replace the
Clean/Solution Tank.
The tabs on the side is what locks the tank on, if they won't release the tank, then you may have to take apart to get it off and replace the tank.
Jan 30, 2008 | Bissell SpotLifter 1716 Bagless Handheld...
Bissell 1960-3 QuickSteamer Plus Upright Vacuum Logo
257 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
