Question about Craftsman 17762 Wet/Dry Vacuum
Wet/Dry Vac Leaking
I have a Sears wet/dry vac and when I vacuum water there is a fine spray coming out of the air outlet and water drips around the rim of the cover. I have removed the filter and cleaned it and repeatedly removed and replaced the cover thinking that it wasn't seated correctly. Any suggestions? Thanks
  • ameyb Aug 01, 2009
    Yes I am.
  • 867 Answers
Are you using a water , foam material filter?
Posted on Aug 01, 2009
I can't find the owner's manual to our shop vac. What's involved in converting it from a dry vac to a wet vac? I think it does both, but I've only ever used it to clean the car.
generally you remove the filter and just use the foam sleeve (if it has one) it should have a float ball in a cage under the filter. this is to keep the water from going into the motor if it gets too full. That is pretty much it. You should have it plugged into a GFCI outlet when using it for wet pick up, also do not pick up flammable or hazardous liquids.
Jul 23, 2011 | Shop Vac 5841627 Wet/Dry Vacuum
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
How do i go from dry vacuming to wet vacuming with the rigid shop vac
can I run my sears shop vac without the paper bag, for dry pickup?
Jan 29, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Moto Brushes Problem... Who could help?
where can i fine moter brushes for my ridgid 5.25 hp 16 gal. wet dry vac.
Oct 02, 2008 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Shop Vac
You **** up water the same way as dirt. It's designed this way, hence the name wet/dry. Just be sure not to get the water in the very top of the unit where the motor sucks the air for cooling ventilation, if water gets in there it can burn up the motor. A little hard way, personal experience, speaking there.
Jul 16, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
177611 wet/dry vac
Either you aren't getting the top on correctly so it will latch, or there maybe a problem with the latches. You should have a one year warranty on this, take it back to Sears and have them look at it.
Nov 13, 2007 | Craftsman 17765 Canister Wet/Dry Vacuum
Craftsman 17762 Wet/Dry Vacuum Logo
242 people viewed this question
Top Craftsman Vacuums Experts
Andrew Taylor
Andrew Taylor
Vernon Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
