Question about Boating
On an kawasaki 2008 ultra 250x supercharge jet ski i am getting oil in drain cap under the air box
finish line
  • 207 Answers
SOURCE: removing starter w/out pulling motor kawasaki jet ski 750 ss
yes but its not easy you pretty much have to take all the exturnal parts off carbs, exhuast airbox if u have one but it can be done make sure you have a swivle for your socketsbest place to get a starter is sbt.com short block tech
Posted on Jun 27, 2009
finish line
  • 207 Answers
SOURCE: 1996 jet ski problems
what kind of ski? do a compression test and change the plugs 1st and comment me back ill be looking for you well figure it out if you have 90 psi for a yamaha or 100+ for a seadoo or kawi
nova2nv
  • 197 Answers
SOURCE: My Polaris freedom(jet ski) starts and runs good
Replace exhuast temp sensor.
Posted on Nov 14, 2009
  • 677 Answers
SOURCE: How Do I Turn Off Or Rewind Hours On 2008 Yamaha
Mate.You buy a new jet ski or don't sell it to anyone that wants a true ski.I will put your i.d. on a list.If you left the key on,you should,ve said so.
Posted on Jun 16, 2010
  • 677 Answers
SOURCE: how to change the oil on a 2009 kawasaki jet ski
You have to pull the oil out of the dipstick tube.You need a vacuum extractor.The dealers use them.Sorry to tell you this.Hope this helps
Posted on Jun 20, 2010
Why does it seem to be lacking power from low to high end?
Kawasaki jet ski - loss of "top end" power. ' Boat/PWC Lubrication ...
www.bobistheoilguy.com > ... > Boat/PWC Lubrication
Jul 5, 2011 - 15 posts
We have two jet skis, had them out yesterday for the holiday. Last fall, I prepared them for winter, as I always do. While getting the Sta-Bil ...
Nov 14, 2015 | kawasaki 2015 Jet Ski Ultra 310LX
What is the gas-oil ratio mixture for a 1995 kawasaki jh750-a4 jet ski
50 to 1 that is 2.5 ounces to the gallon for pleasure riding
40 to 1 that is 3.2 ounces to the gallon for racing
May 09, 2015 | kawasaki 2010 Jet Ski Ultra 260X
Lost ignition keys, what do I do?
what a pickle you people put yourselves in . go see the dealer is only option you have
Mar 21, 2015 | kawasaki 2007 Jet Ski Ultra 250X
Jet ski troubleshooting
kawasaki ultra 260's are only cooled by lake or sea water so if the water supply gets blocked then it will overheat ! did it definatly overheat or just loose power because the superchargers do sieze up due to damp air or the pully bearing , also the dipsticks on them sometimes shear off and lock the cogs ! does the engine still run up on a hose pipe ? also has the ski been left a long time not used without fogging the valves in the head ? this is my job so get back to me ( 30 yrs ) ..
Dec 28, 2013 | kawasaki 2010 Jet Ski Ultra 260X
Oil change
Ask the dealer if this affects the warranty.
Nov 28, 2013 | kawasaki 2010 Jet Ski Ultra 260X
What oil and how to you check it in a 93 kawsaki 750 jet ski, not engine oil the transmission oil
Your 750 jet ski does not have a gear box. If you are referring to what looks like a filler cap on the front of the motor, that is the generator/flywheel cover and it is a dry compartment and should remain that way.
Jun 11, 2011 | Encore Software Kawasaki Jet Ski...
I have an kawaski 440 jet ski and how much oil does it take in the gear box and what kind
Your 440 jet ski does not have a gear box. If you are referring to what looks like a filler cap on the front of the motor, that is the generator/flywheel cover and it is a dry compartment and should remain that way.
Apr 16, 2011 | kawasaki Full Suspension Mountain Bike Men
Jet ski bogs out under load.
I had a similar experience with that model. It turned out to be a mouse nest in the water box. However , in this case i think you just have some moisture corrosion on the rubber tipped needle in the carburetor. Clean that part of the carb and do not alter the tiny spring in any way. If that does not work open the electronics box, if it is wet , dry it out , and seal it back up. Those are the three things I know of that will cause your problem. Start with the carb.
Apr 06, 2010 | Encore Software Kawasaki Jet Ski...
I have a 2001 ultra 130 di jet ski and with two people on it that do not weigh much the jet ski will roll over at idle speed if you are not really carefull. Please help, it is a great jet ski for one...
Many hulls when turned sharply below planing speed will flip when riding two up. When wearing a neoprene suit you need to jump in periodically just to cool off. Make sure you have drained all the compartments in the hull of water every time you take the boat out of the water. I purchased a ski once that would not plane off and had a dry engine compartment. When I pulled the plug at the back several gallons of water came out. It made all the difference in the world losing all the ballast.
Oct 12, 2009 | kawasaki Full Suspension Mountain Bike Men
Boating Logo
133 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
