Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Frigidaire Gallery stove top spark module is firing once every 30 seconds when turned off.
  • 15,935 Answers
Ok - this is a question regarding a stove - not a fridge - as indicated.
:D
If the ignitors on a gas stove top continuously spark and only stop when the electricity is turned off the problem may be a stuck relay.
Turn off the electricity (unplug) for a long period of time perhaps overnight. Sometimes the relay will automatically reset.
Posted on Aug 01, 2009
  • blueextc3221
    blueextc3221 Aug 01, 2009
    There are a few other things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse.
    The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it.
    Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
Can I use Cast Iron Pots and Skillets on my new Frigidaire Gallery Stove Top?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
Oct 09, 2014 | Kitchen Ranges
Frigidaire stove error code
F68 = Power Line Failure. Turn power off for 30 seconds. If this does not correct it, check the electrical supply for proper voltage, ground, and polarity, if all of this checks ok replace the EOC-Display board
Aug 08, 2014 | Frigidaire Gallery 30 " Stainless Steel...
My frigidaire gallery series oven made a popping noise while heating up dinner in oven and now the whole oven is not working
Hello jnjpelli - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. If the oven does not turned on, then more than likely there seems to be a power supply issue. Also try checking the breaker and the power connections located on the back of the range. If any of these suggestions prove to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues
Jan 19, 2013 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
None of my stove top burners will spark to ignite
There is an ignition module that sparks when it calls for lighting. This module could have a loose connection or be dead.
Apr 03, 2010 | Frigidaire PLEF398AC Electric Kitchen...
What is a f13 error code on a Frigidaire Gallery smooth top stove
Hi danair2,
the F13 error is related to the clock. this error can occur when the clock looses communication between the keypad or any of the sensor in the stove, including the heat probe. sometimes resetting the power will fix the problem.
try disconnecting power to the stove completely and flip the corresponding breaker on and off on the breaker box.
wait 30 seconds and than turn everything back on.
if the problem returns after power-up, replace the clock.
Regards
R.K.
Aug 14, 2009 | Kitchen Ranges
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
371 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
