SOURCE: I have a 60" Lesco
If it were me I would check the PTO switch with it running and use a dvm or test light to see if switch is working or defective , you could just have a bad wire connector at the switch or at PTO clutch ....look for discoloration or spread terminals, good luck
SOURCE: I need a manual for a Lesco Zero Turn Lawnmower
Richard you will have to contact the dealer with make and model # , I did search quite a bit which you may want to try, Google search your make and model# manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
