Question about Friedrich D40C Dehumidifier
Dehumidifier has shut down
On/off switch does not work. unit was running before it was unplugged, but would not respond to on/off switch. Once power cord was unplugged and replugged, the unit would not turn on.
The GFCI outlet needed to be reset. There was no problem with the dehumidifier itself.
Posted on Aug 02, 2009
When turn off. makes a humming sound. compressor seems to be running.
Have same issue with 3 year old Frigidaire dehumidifier purchased in 2012. Must unplug to stop compressor running with power switch turned off. Unit gets hot and smells. Unplugging creates arcs at outlet since unit is pulling a lot of power. Plugging back in after some hours will make it appear to run normally and again remove moisture but it will not shut off when the fan goes off (humidistat bad?) and the set-point is reached. Cannot leave plugged in due to safetty/fire/overheating concern. Have not found answer on this forum or any other so far.
Sep 15, 2013 | Frigidaire FAD704TDP Dehumidifier
Does the Fan on a Haier HD456E always run,
I believe the fan is designed to run all the time, and no, it costs very little to run an 18w fan. You can use a timed socket, or switch it on and off when needed. I don't believe the Haier has specific switching times.
Apr 16, 2012 | Haier HD456 Dehumidifier
The bucket full light is on and will not shut off
This usually happens when either the Float Valve in the bucket is stuck in the UP position (if yours is so equipped. Jiggle it to get it to return to the DOWN position.
If you humidifier's bucket is not so equipped. That's usually an indication that the bucket was not reinstalled properly, after it was removed. To check and correct this, turn the Master ON/OFF Switch to OFF and unplug the unit. Remove the bucket and reinsert it, making sure that it fits "squarely" in the bucket holder from Top to Bottom. Once installed, make sure the bottom of the bucket is not tilted down in any way. Plug the unit back in and turn the Master ON/OFF Switch to ON. If it was reinstalled correctly, the bucket full light should have gone off and the unit will run as it should, if the humidity extraction level is set low enough.
Hope this helped you to troubleshoot and solve the problem.
Jun 23, 2011 | LG LHD65EBL Dehumidifier
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
Unit was working fine and simply quit. There is power to the unit however it does not turn on there are no lights . The resevoir is not full but the unit does not work
It may simply need to be reset. Turn the Master ON/OFF switch to OFF. Unplug the unit and wait 12 - 15 minutes before plugging it back in. Once its plugged in, turn ON the Master ON/OFF switch and set your controls. If it's not working then .. check the position of the water collection bucket. It may not be tripping the safety switch. Also be sure that the unit is sitting on a level surface.
Hope this helped you to troubleshoot the problem.
Mar 30, 2011 | Haier HDN655E Dehumidifier
Dehumidifer runs for about 45sec to 1minute and then shuts off. wqhat would be making this happen
If it does that consistently, then it's likely that the compressor is overheating and shutting down. (It has a thermal overload circuit to prevent a potential fire). Another cause could be a malfunction of the control circuit board which runs all functions of the unit. To check for possible compressor problem, unplug the unit, remove the housing to expose the compressor, plug it back in and power it up. When it shuts down, feel the compressor. It should be warm to the touch, but definitely not so hot that it singes your fingers.
If you find that the compressor is just normal warm, then the control circuit board is shot and needs to be replaced. Check with the merchant or manufacturer for availability & cost. If prohibitive, you're better off simply replacing that unit with a new one.
Jun 10, 2009 | Goldstar DH304 Dehumidifier
Bucket fills, doesn't stop
make sure unit is level , the cut off switch will not work if not level
Jun 07, 2009 | LG LD65EL Dehumidifier
Will not run after a few seconds
sounds like a main pc board and or capacitor problem
Sep 17, 2007 | Kenmore 54351 Dehumidifier
The main switch is broken off and it does not turn on
You have to remove the entire wrapper to get to the control circuit board, make sure you unplug unit!! Locate the small white wires that plug into the board and go to the humidity switch.Unplug the connector at the board and plug the machine in and see if everything runs. ps make sure you reinstall the bucket or unit will not run. If machine runs replace that humidity control. The plug on the board is usually white. The other white wire is 4 the light. I hope this helps./
Sep 05, 2007 | Goldstar DH304 Dehumidifier
Friedrich D40C Dehumidifier Logo
208 people viewed this question
Top Friedrich Dehumidifiers Experts
jhnolson
J.D. Browning
J.D. Browning
bobalix
Are you a Friedrich Dehumidifier Expert? Answer questions, earn points and help others
