Question about Canon PIXMA MP470 All-in-One Printer
Will not print
I changed the correct cartridges and now it will not print
  • 114 Answers
Check software and leads are correctly fitted.
Posted on Aug 01, 2009
Printer display says "Print cartirdge(s)
when you replaced them did you go into the menu located on the printer and tell the printer that you were changing the cartridges out? If not the printer thinks that you still have not replaced them. To do this all you have to do is go into the menu select the option that says change my cartridges (or something like that) and remove the new ones and put them right back in the printer should then recognize the cartridges.
Jun 30, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
I changed two colour ink cartridges on my Canon iP4200 printer. Now it won't print colour. The pattern check does not print any colour.
You might want to double check to make sure that your printer takes two color cartridges? If I remember correctly, the Pixma takes one black and one color cartridge? If you put a color cartridge in the black ink assembly that would cause it to stop printing.
Double check and make sure that you have one black cartridge in the correct place and one color on the other side.
Apr 22, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
How to change the cartrige
1.Out tray (in down position)
2. press Power button
3. open top cover
4. raise cradle latch
5. lift out cartridge
6.Remove the replacement print cartridge from its packaging and carefully
remove the protective vinyl tape.
7.Insert the print cartridge firmly into the cradle. Secure the cradle latch.
You hear a click when the latch is fully secured.
8. Close the top cover.
If the Print Cartridge Status light continues to blink after installing a new
print cartridge, check the part number on the cartridge to verify that the
correct cartridge is installed.
Thank You
Oct 05, 2010 | HP DeskJet 920c InkJet Printer
Printer won't print, message says ''wrong cartridge'' I have the correct cartridges installed and it still will not print.
Would I be correct in thinking that you have just changed the cartidge?
If so, then remove the cartridge and check that you have removed all the transit seals that are fitted to prevent leakage in transit.
Mar 15, 2010 | Canon Office Equipment & Supplies
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
After changing the ink cartridge, my printer wouldn't print.
change cartridge from 60 to 60l and printer wouldn't recognize cartridges
Dec 21, 2008 | HP Photosmart C3180 All-In-One InkJet...
Hp c4280 printer/print cartridges
Have you checked to make sure that you have the correct replacement cartridge?
In general if it simply will not go into position and you know you have the correct cartridge, then you need to take it back to where you bought it and request a replacement - because it is defective.
Apr 14, 2008 | HP PhotoSmart C4280 Laser Printer
Colour Ink
1. On your PC, go to Start, Programs (Windows XP: All Programs), Lexmark series.
2. Select the Solution Center.
3. When the Solution Center appears, click on the Maintenance button.
4. Select the option to Install a new print cartridge. The carrier should slide over at this point and allow you to insert and/or remove cartridges.
5. Make sure the correct cartridges are installed inside the printer first, then inform the software which cartridges have been installed. Note: This applies also to installation of a single cartridge.
6. Print the Print Alignment page to ensure the print quality is satisfactory.
7. Close the Solution Center.
Mar 23, 2008 | Lexmark X1150 All-In-One InkJet Printer
We just attached the macbook to the hppsc 1350v all in one printer and new print cartridges. When attempting to print, message reads"color print cartridge not compatible with this printer". We know we have...
Just to confirm pls:
1. the new print cartridges are original HP inks;
2. you have remove the bright pink tape from the ink cartridges;
3. the black is on the right side and the color is on the left side.
You can try removing both cartridges and clean the gold colored contacts where the pink tape was. Pls do the same to the mate pins in the cartridge holder in the printer.
Try again. If this does not be corrective, you may need to change inks again.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 02, 2008 | Computers & Internet
Changed ink cartridge, now printing with green hue
check the magenta cartridge is it not dry or try to clean the magenta cartridge nozzle and see. bye
Sep 24, 2007 | Canon I960 InkJet Photo Printer
Canon PIXMA MP470 All-in-One Printer Logo
old marine
old marine
