Could be anything from a broken clutch to a broken drive shaft. I once had a customer with that trouble and the outer cv joint and drive shaft had lost all it's splines.
Another customer had an engine mounting break allowing the power unit to drop far enough to disengage a drive shaft from the transmission..
Only checking will reveal the problem...
Testimonial: "was able to drive until i smelt clutch fluid adjusted cable but nothing,can start the van in gear but with no juddering"
SOURCE: fiat ducato timingbelt problem
on the front engine pulley/harmonic balancer or in a hole on the bellhousing.
SOURCE: fitting timing belt on my fiat ducato 2.5
u probs be best getting it to a garrage because if done wrong it can cause more problems like bending pistons
SOURCE: Fiat Palio-1.2 ELX (Petrol) clutch ''not-working''
Even I had this problem. After sometime engaging gear was difficult. There are two reasons. First, it could be leakage of servo fuel/brake fluid from the master cylinder on the clutch side or it could be due to the wear of the pressure plate.
SOURCE: i need a exploded diagram of a fiat ducato 5 speed manual gearbox plaese can someone help
I am sorry this is contained in the factory service manual and we do not have that to share online due to copyright protected material.
