Question about Canon MP830 All-In-One Printer
Light in a Canon MP830's scanner
Can the light bulb in a Canon MP830's scanner be replaced? how?
    President:
  • 3,085 Answers
No, spare parts are not available.
Posted on Aug 01, 2009
  • Barbie KingScott Oct 17, 2012
    That's a shame. This little mp830 has worked very hard an served me well. It still works very well except that white paper scans a little gray. I replaced it because there were cross platform networking issues, but I wanted to use it as a copier.
3 Suggested Answers
komguy
  • 2306 Answers
SOURCE: feed switch & alrm light on
The MP 830 usually will give you an error code in the display. If these lights just come on and you don't hear anything moving inside and no error codes, the main logic board could be bad. A rather expensive repair. Have you tried unplugging the printer and plugging in again?
Posted on Jun 25, 2009
SOURCE: canon mp830 service error 5c310 alarm light keeps
http://damnprinter.com/226/canon-service-call-errors.html
http://www.fixyourownprinter.com/forums/inkjet/26091
You need to clean your waste ink i think. For troubleshooting purposes, please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Posted on May 17, 2010
Scanner bulb replacement
replace the flat strip cable if problem not solved then replace the whole scanner unit.
Aug 28, 2012 | Canon PIXMA MP830 All-In-One InkJet...
Have Pixma MP830 and scans in parts not the hole page.Was everything ok the day before
Does the Scanner assembly [ Canon Part No:QKI-2222-000] fit both the Canon MP780 and MP830 models?
Jim
May 11, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
"scanner not operationg properly" on my Canon MP830
Confirm the connection between the scanning unit and the
logic board.Replace theunit, orlogic board.
Sep 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Feed switch & alrm light on
Jun 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
CANON PIXMA MP830 Error Msg: Scanner not working correctly.
the error message: "Scanner is not operating correctly." The scanner is definitely unlocked.
Nov 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 Error Message: Scanner is not operating correctly.
This problem sucks. It sounds like the scanner has actually gone bad. This can be a couple of things. The actual ccd unit inside the scanner, a position sensor, a motor or a wire harness.
The latter two are fairly unlikely, the first two more likely. Most probable is the CCD unit. I don't think Canon sells it as a separate piece, but it comes inside a replacement scanner assembly. These complete scanner units are expensive. You'll have to check with your local Canon shop to see what they cost.
Nov 06, 2008 | Canon PIXMA MP830 All-In-One InkJet...
MP830 canon 3in1 scanner lock.
my mp830 will print, copy, fax but it will not scan to the computer. Please help
Sep 10, 2008 | Canon MP830 All-In-One Printer
Canon MP830 wont scan
you have to use other programs such as photoshop to use the scanner
Mar 28, 2008 | Canon PIXMA MP830 All-In-One InkJet...
251 people viewed this question
old marine
old marine
