Question about Ubi Soft Chessmaster 10th Edition
Lost the first CD
I got the 3 CD, 10th edition of chessmaster. Now I lost my first CD. How do I resinstall and continue to play. I have other 2 CD intact with me
  • 63 Answers
Ok here you will find what you need so ckick and then choose a link: http://www.torrentz.com/a98f04c2fe9cc32d82fcf1bc0030c91aa0cff357
Posted on Sep 27, 2009
I purchased chessmaster 10th edition and installed to computer when i hit the play button for startup it asks to insert disc 1 i would like to know why this is required when the program is installed ...
i am sorry to give u bad news, game CM is game that need disc to run the game because a lot of stuff that still need to run the program left behind in the disc. it was factory setting.
But u can use alternative way by make the disc to image then run it with daemon tool.
first u need program that can make image file like .iso, .nrg, etc. ( i use nero)
make an image file from CD 1 and CD 2 and save it in computer.
second install program that can make image drive to run image disc (i use daemon tool).
make one image drive then mount the image disc to the drive.
now u can play without real disc. (after finished play the game unmount the image disc)
hope this helpful
Feb 15, 2011 | Ubi Soft Computers & Internet
I get an error 1606 message while trying to install the chessmaster 10th edition to my lap tpo
Hello there,
Error 1606 is a windows Error here is the link to help you fix the problem
http://support.microsoft.com/kb/315352
To resolve this behavior, follow these steps.
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. Locate and then click the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  4. In the right pane of Registry Editor, double-click Common Administrative Tools.
  5. In the Value data box , type the following line, and then click OK: %ALLUSERSPROFILE%\Start Menu\Programs\Administrative Tools
  6. On the File menu, click Exit to quit Registry Editor.
  7. Restart the computer.
Thank you don't forget to Rate
Jan 25, 2011 | Ubi Soft Chessmaster 10th Edition
Hi, my chessmaster 10 edition becomes unresponsive when busy playing. The time of the relevant player stops and the task manager shows that it is not responding. After about 3 minutes it sorts itself out...
actual your wrong on all acounts... your chessmaster should run just fine on your version of windows.. it sounds like it glitching because of you computer itself.. now chess doesnt sound like a game that needs alot of graphics to play but the graphics card can be one.. i would suggest checking your core temp (cpu fan) in your bios (look it up buddy on how to's) and the search normal temps.. your computer needs to run at a healthy temp or no matter how good your computer is it will overheat and become useless... but it can also be your processor or your about of ram... try deleteing old files you dont use to make disk space and after that go to start>all programs>accessories>system tools>disk cleanup.. and then after that is done system tool> disdefragment and let that run.... and if that doesnt help tell me and i can give more suggestions if it fails
Dec 10, 2010 | Ubi Soft Chessmaster 10th Edition
Cannot initialize 3D engine
the problem on the Chessmaster 10th Cannot initialize 3D engine is that the game support only 1024x768 on screen resolution. Do that and works fine. Peace for all.
Jan 06, 2010 | Ubi Soft Chessmaster 10th Edition
I WANT TO PLAY CHESS WITHOUT LOOKING WHERE MY CD IS EVERY TIME .
keep it inserted in the drive bay or download a cloning software to copy the cd.
Sep 30, 2009 | Ubi Soft Chessmaster 10th Edition
"Failed to attach personality"
When I start Chessmaster, and click on Play-Trining Mode, it says "failed to attach personalities", and I can't play chess
Jul 29, 2009 | Ubi Soft Chessmaster 10th Edition
No sound for chessmaster 10th edition
You need to go to http://forums.ubi.com/eve/forums/a/tpc/f/760105752/m/5081052236 and download all patches in order.
If that doesnt work you will need to search the program file tree (Ubisoft/Chess/Data/User or something along those lines) for a CMDefault.ini cm.ini or YourName.ini (denoted by a notepad with a yellow gear superimposed) first MAKE A COPY OF THIS FILE AND NAME IT SOMETHING ELSE, then open the origional, and look for a modifer such as
sound=
or
playsound=
Or something like that...
If it is set to 0 or false then all you have to do is set it to 1 or true
THE SAME WAY IT IS WRITTEN
so if you see for example
sound=0
you will put
sound=1
NOT sound= 1 or sound =1 or sound= 11
Same for true / false
You also may see it either way
sound=true
sound= true
Save and try it, if the program crashes or fails to load, you made a mistake, delete the INI file and RENAME the COPY to EXACTLY the title of the ORIGIONAL.
And you'll be back where you started.
Mar 26, 2009 | Ubi Soft Chessmaster 10th Edition
CD play function plays music, then fails priior to completion
Yeah if your spec doesn't meet the requirements it will hang. Also the most possible cause is fault in downloading or there is error on the file itself.
Hope this help.
Mar 11, 2009 | HP Compaq Presario SR1503wm PC Desktop
Chessmaster 10th error message
you need a graphics card more than 128 mb to run
Dec 22, 2008 | Ubi Soft Chessmaster 10th Edition
Ubi Soft Chessmaster 10th Edition Logo
381 people viewed this question
Top Ubi Soft Video Game Consoles & Games Experts
Hanzu
dante
Tom Chichester
Are you an Ubi Soft Video Game Console and Game Expert? Answer questions, earn points and help others
