Question about Lenovo 3000 N500 Notebook
Lenovo N500 shut down after 30 seconds max, tested whith another processor and memory ,AC-adapter , battery and mother board...but no result
  • 32 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
17
Posted on Aug 01, 2009
I have alenovo ibm thinkpad R60 laptop but it does not starts in battery aswell as in ac.Sometimes it get started but after few seconds it automatically shutdowns.
Apart from possibly failed battery and/or adapter, spontaneous shutdowns can be signs of overheating or PREVIOUSLY overheated processor, regardless of make or model.
First step is to disconnect BOTH the battery and adapter, press and hold the power button for 5 seconds to release any static electricity then try powering it up with ADAPTER ONLY, then BATTERY ONLY, then BOTH; just to check which setup would repsoduce the symptom.
If the above steps do not isolate the cause of the problem, test the machine with a spare battery and/or adapter (or test your computers battery & adapter on a similar machine) to see if the problem follows the computer itself. If it does, then the next step is to reapply thermal compound to the processor.
If that doesn't make it work correctly, then the processor and motherboard will have to be tested for functionality and one or both of them may have to be replaced.
Aug 09, 2011 | IBM 41W5278 - IBM Lenovo ThinkPad R60,...
My problem with the Gigabyte GA-8I848P-G Motherboard is when i press the power button I do not hear the speaker beep I also do not see the display on my monitor screen after a few seconds my cpu is...
Hi, what you have not tested for isolation is your power supply, re-seating of processor for 20 minutes, cmos clearing or battery removal and mother board swapping. If all your isolation seems futile the worst is the mother board.
Jun 22, 2011 | Gigabyte GA-8I848P-G Motherboard
Five long beeps at a range of five seconds then, repeats
Five long beeps for a modern motherboards indicates a processor failure. If you wish to remove the processor and re-seat it (reconnect it to see if it begins to work again) make sure to get some thermal compound to put between the CPU chip and the heatsink. More info at: http://www.hardwaresecrets.com/article/How-To-Correctly-Apply-Thermal-Grease/274
POST AMI BIOS beep codes
  • 1 - Memory refresh timer error
  • 2 - Parity error in base memory (first 64 KiB block)
  • 3 - Base memory read/write test error
  • 4 - Mother board timer not operational (check all PSU to MB connectors seated)
  • 5 - Processor failure
  • 6 - 8042 Gate A20 test error (cannot switch to protected mode)
  • 7 - General exception error (processor exception interrupt error)
  • 8 - Display memory error (system video adapter)
  • 9 - AMI BIOS ROM checksum error
  • 10 - CMOS shutdown register read/write error
  • 11 - Cache memory test failed
  • 12 - Mother board does not detect a RAM module (continuous beeping)
Source: Wikipedia
Feb 28, 2011 | Computers & Internet
I turned it off. Next morning there was no screen when I turned it on.
Please perform the following steps:
Power drain process:
1. Shut the computer down.
2. Disconnect the AC adapter and remove the battery.
3. Press the power button down for about 30-60 seconds.
4. Reconnect the AC adapter and the battery.
5. Restart the computer.
Alternately you can test your Notebook power by removing and inserting the Memory and Hard-Disk in their locations.
May 25, 2010 | Acer Aspire 5100 Notebook
My Lenovo N500 does not want to startup but there is a light that stays on all the time, it is next to the start button
The light that stays on is probably a power indicator. Remove AC adapter and battery. Hold power button down for 20 seconds. Put battery back in and reconnect AC adapter. Try to start your computer.
Jul 30, 2009 | Lenovo 3000 N500 Notebook
Lenovo 3000 N200
sounds like the mother board maybe on its way out - is it under warranty?
Jul 24, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Lenovo 3000 n100 won't power up
I had posted the Aug 19, 2008 comment about having this problem twice. I tried a new universal AC adapter, and it worked! (new adapter is a Targus APA63US) Now battery is charging and laptop also runs on AC alone. So perhaps it's an adapter problem instead of a battery problem. Get one at a store with a good return policy, so if it doesn't work for you, just return it. And if it does work, then happier days. I've had mine about 2 weeks. So far so good, though with what I've learned about Lenovo since having this problem, it wouldn't surprise me if something else goes wrong, or if the damn thing just blew up, ha ha. Also, this adapter set me back about $100 that I really should not have needed to spend! arrgggh ...
Cheers and Best of Luck and hope this helps other frustrated Lenovo owners!
Jul 11, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Will not boot up or turn on though it is getting power
The Charger could be bad, Try replacing that, or let charge, then try to turn on. The laptop might not boot with AC power. kinda stupid but maybe. If that doesn't work, the AC adapter is bad.
Jun 12, 2008 | Lenovo 3000 N100 0689 Notebook
Lenovo 3000 N500 Notebook Logo
323 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
