I connected a sata dvd writer (ts-h653) from dell pc to my assembled desktop.when i try to copy cd from dvd drive to hdd an error occurred on half way.os is vista.
  • Jestin Zachariah
    Jestin Zachariah May 11, 2010
    Do it reported as :-
    "A Disk Read Error Occurred. Press CTRL+ALT+DEL to restart"
THE NEW CONNECTIONS MADE FOR FOR SATA POWER ARE INFERIOR TO THE 4-PIN, CONTACTS ARE OF VARIOUS LENGTHS,REPLACE WITH THE TIGHTEST AND BEEFIEST YOU CAN FIND
Posted on Oct 28, 2010
    Sergeant:
  • 205 Answers
Plse install nero software www.download.com download it
Posted on Aug 01, 2009
Schematics Diagrams home pc
http://www.interfacebus.com/SATA_Pinout.html
here you see how to connect the sata cabel and the power cabel.
same way for CD/DVD-WRITER.
sata narrow.signal/data.power is wide
Apr 24, 2013 | Dell Computers & Internet
The cd/dvd writer constantly open and close once a disc is inserted. On insertion of a disc, cd/dvd player will read the data on the disc. Windows Media player will display realtime image of the movie,...
Hi Charles,
The issue is due to the driver corruption. You need not worry, there is a simple solution for this.
Go to device manage --> right click on your CD/DVD drive and then click uninstall and then restart your computer. Do not keep any CDs while you do this. Just try this out.
Oct 25, 2010 | Dell Dimension E520 PC Desktop
My Toshiba ts-h653 cd/dvd RW drive failed. the
If the drive is trashed, just force the drawer open. If you don't want to do that, you should be able to disassemble the drive enough to get the disk out by removing screws... Sometimes the screws are underneath stickers, or warranty stickers, etc etc.
May 09, 2010 | HP Computers & Internet
Sata hdd windows dell recovery cd will partition install windows
The system is originally designed to use IDE HDD, make sure the necessary chages for Sata HDD are made in the BIOS, next make sure the Recovery disc is fine without any scratches. You can order a new Windows OEM recovery disc by calling Dell tech support (1-800-624-9896-US) and try installing the OS. The disc will cost you not more than $12.
Nov 15, 2009 | Dell Dimension 4700 PC Desktop
Dageezer sdays the LG GH22 dvd writer is a sata
You can refer to the following user manual , for the drive installation
http://support.dell.com/support/edocs/systems/dim3100/en/sm/parts0.htm#wp1244168
Thanks for using Fixya
proton
Nov 08, 2009 | Dell Dimension 3100 PC Desktop
PC Does not boot up with LG SATA DVD Writer
Did you try to move the small jumper next to the connector on the back of the DVD writer.
Then try to choose different places to connect your DVD on the motherboard.
Check if you have the right driver or reinstall it.
Hope its help, don't forget to rate.
Cheers
Aug 19, 2009 | ASUS K8V-MX Motherboard
Selected boot device is not available
I had the same issue with my dell dimension 2400. The issue I was having resulted in the connection to the drive was loose. Try taking off the side of the case, find the drives in question and reseating the plugins. My pc was quite a bit older though and i don't know if this will be your solution, but its worth a shot. You can even try installing a different cable and swapping to another power supply plug.
Aug 10, 2009 | Dell Dimension 8400 PC Desktop
Compatible CD/DVD Writer Models for the Dell Inspiron 9400
Replacements are UC823 and TS-L632 / TS-L632D , TS-L632D/DEKH.
If you had problem with TS-L632 you may need to update the bios.
Replacement here:
UC823 - DVD+RW 8X Optical Drive
Feb 08, 2009 | Dell Inspiron 9400 Notebook
Problems with getting bootable disks to be read - Dell/VISTA
Solution:
i) when you start your system press button(F8 or F10 or DEL) so that you can go into BIOS menu now     try explore BIOS menu and see whether
  a) SATA 0 - ST325082045 3.ADG
  b) SATA 1 HL-DT-STDVD +-RW GSA H31
   are just visbile(in sense, you can see them in  BIOS writen ), this will make sure system is able to        detect them, we will be assured that your a)HARD DISK b) DVD writer   are working perfectly ......
    if so without any hesitation format or reload system with  Windows Vista....
ii) if otherwise any one of them or both are not visible in your BIOS Menu like a)HARD DISK b)DVD        writer
   try to open your computer tower and locate cables that are going to ur DVD writer, HARD DISK
   and reseat them(just remove the cable and place them again), by this way we are making sure that    no loose connections are existing..............you can even try new cables .......
   now restart ur system and go in to BIOS menu and repeat the step (i) ....
   if you are enable to see any one or both
      a) SATA 0 - ST325082045 3.ADG ....................HARD DISK
      b) SATA 1 HL-DT-STDVD +-RW GSA H31................DVD WRITER
  then you are having problem with either HARD DISK OR DVD WRITER  and you have to buy them .....
 Thanking you
M. Sridhar
Dec 26, 2008 | Dell Inspiron 531 Athlon 64 X2 4400+...
Need to replace dvd writer ,model ts-h653 in a hp m8300f pc .
yes you can replace any dvd writer you want as long as it fits on the casing
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
1,051 people viewed this question
David Payne
David Payne
