Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
My Hoover U6434 makes a knocking sound when I turn if off and it powers down. The belts and brush roll are fine. Any idea's? Thank you, mpipes
  • mickey_pipes Aug 09, 2009
    It makes a knocking sound when it powers down.
    Thanks so much.
    mp
  • Alex May 11, 2010
    does it make a clicking noise oppose to a knocking noise ?
    Master:
  • 379 Answers
Its probobly a pice of dirt being slung around on some hair or thread. try cleaning the fan and look carfuly for hair tightly raped around the shaft.
Posted on Aug 01, 2009
How to replace belt on hoover SH40060 SWEEPER
Remove the screws from the bottom of the power nozzle so you can remove the cover to gain access to the belt. Remove the brush roll, pull the end caps off the brush roll if possible to clean out hair and debris. Make sure brush roll will spin freely. Install new belt and reassemble.
Feb 20, 2015 | Hoover Vacuums
How do I replace the belt for this model
Make sure vacuum is not plugged in to power outlet. Lay it upside down and remove 4 screws from bottom plate covering brush roll. Remove bottom plate and pull the brush roll out. Clean hair and debris from brush roll and make sure it spins freely. Remove end caps from brush roll if possible and clean debris out. Install new belt around motor shaft then insert brush roll into belt and pull on brush roll to give you enough leverage to stretch belt far enough to put. Brush roll back into position. Reinstall bottom plate and screws. Make sure brush roll will turn before turning vacuum back on. Belt will lose elasticity and should be replaced twice a year.
Jan 17, 2015 | Hoover U5434-900 WindTunnel Plus Bagged...
Brush won't spin on hoover wind tunnel bag less upright when on carpet, belts are fine
The belts may look fine but may be stretched and worn. Replace them. Make sure brush spins free. Idler pulley should tighten belt tension when handle is released
Jul 25, 2014 | Hoover U6630-900 WindTunnel Bagless...
Why does drive belt on Hoover U6434 keeps slipping off. Even new ones.
Hi! If you have replaced the belt with a new one and your brush-roll is still not spinning, your brush-roll may need to be replaced. Remove the brushroll and clear it of hair and debris. Spin the end caps with your hand. They should spin easily with no tension. Inspect the area on the brushroll where the belt rests on for damages. To order a replacement brushroll click on this link. Search Results It could also be that the incorrect belt is being used with the vacuum. Make sure you are using genuine Hoover parts when replacing the belt. Click on these links to order a replacement belt. Search Results & Search Results
Hope this was helpful!
Jun 08, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Drive belt on Hoover U6434 keeps slipping off. Even new ones.
Check the motor shaft for residue from a previously burned belt. Also the brush roller may be defective.
Belt replacement
Your model requires (2) different belts. Here is a link to the belts you need and to the manual:
U6434-900 Brush Roll Belt
U6434-900 Self-Propel Belt
U6434-900 Manual
Nov 25, 2009 | Hoover U6434-900 Bagged Upright Vacuum
Roller doesn't turn...no forward or backward...
Check the belt, if it's a belt driven brush roller. If not, check the bearings of the roller. You may need to replace the brush roller. Take it to a local shop and have it looked at.
Jul 29, 2009 | Hoover U6434-900 Bagged Upright Vacuum
Hoover U6434-900 Brush roll not spinning, has new belt.
I took the top of the vacuum apart and found the cable that drives the wheels was broken. I am going to order a new cable.
Mar 22, 2009 | Hoover U6434-900 Bagged Upright Vacuum
Hoover Wind Tunnel
If this is new, you have a years warranty on it, take it for repair. Did you get the right belts, the numbers are 38528035 for the flat belt and 38528034 for the V belt. Also if you are catching something like a towel or area rug in the brush roll, it will knock of the belt. Is the brush roll turning freely. If not then it needs to be replaced, does it motor sound ok? If not then there is a problem with it.
Mar 09, 2008 | Vacuums
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
126 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
