Question about Dryers
Dryer trips electricity is70cuk indesit
When i close the door it tripselectricity
  • Raymond Richards
    Raymond Richards May 11, 2010
    is you dryer gas or electric?
    President:
  • 1,723 Answers
There is a pinched wire. need to open up the top to inspect and fix pinched wire.
Posted on Aug 01, 2009
Washer is not working?
Most likely solution: The door latch assembly. When the door closes, the internal latch electronics must "sense" that the door is closed, but sometimes doesn't. When it correctly senses a closed door, it "locks" the door (electronically) and the door can't be opened until the machine has been OFF for about 100 secs. If the door doesn't "lock" when closed, it's just not sensing that it's closed. Solution: Close the door a bit more forcefully. I've seen cases where the door would need to be closed pretty hard, 3-4 times before it "locked". Once it senses the door is closed, and locks, the machine operates normally. The latch assy can be replaced, but often develops the same problem, eventually. Slamming the door won't hurt it.
Jun 18, 2015 | Malber WD2000 Front Load Washer / Dryer
I have liftmaster door opener 41a5021-1d. Using the remote door closes only half way. how can I repair this problem?
When the motor stops in the down position, pull the emergency release handle. Push the door fully closed by hand then engage the emergency handle. Open the door with the remote and then close it with the remote to make sure the door closes completely.
Oct 10, 2014 | Building Materials
Linear garage door opens and closes when close to unit about 10 '
when the door stops moving when going down, pull the emergency release handle on the door and then push the door closed by hand. Once it's closed push the emergency handle back so it engages the chain. Open the door and close it a few times to make sure it closes all the way with the motor.
Oct 01, 2014 | Linear Corporation Linear Garage Door...
What do I need to do in order to get the back door on the passenger side to close? A tech from AAA said I needed a spring for the door latch?
if it won`t close look at the door latch mechanism. there should be two u shaped claws that close around the door striker plate pin, sometimes these get closed before the door is closed causing the door not to close and stay closed. if they are closed(claws) pull the door handle to open the door and take something and push the claws out(open) then close the door.
Jul 08, 2014 | 2000 Plymouth Neon
2005 malibu passengers door in closed position door will not open feels like dod is off how do you open door or remove door panel while door is closed
that's no fun removing one with the door closed.. Try everything first make sure key has door unlocked try to open from inside and outside. If not get a slim jim and try that to open door.. Taking door panel off with door closed is not good ..
Apr 06, 2014 | 2005 Chevrolet Malibu
Mazda 6 2005 driver door jammed
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Jan 04, 2013 | 2004 Mazda 6 Sport
I have a samsung wf316law\xaa washer.I started a load of clothes and went out later and it had stopped early in first few cycles.I got the door open by pulling real hard took clothes to finish them.Now the...
hello,
solution bellow.
There is disclosed a method of controlling an automatic door opening/closing apparatus
for a washing machine that includes the steps of determining whether or not there is an error in
an automatic door opening or closing operation carried out in response to a command to open or
close the washing machine's door; determining if the erroneous operation has been
repeated more than a predetermined number of times according to consecutive incoming commands to open or close the door; and when erroneous operation has repeated more than the predetermined number of times, ignoring a subsequent command to open or close the door.
1. A method of controlling an automatic door opening/closing apparatus for a washing machine door, the method comprising the steps of: determining whether or not there is an error in an automatic door opening or closing operation which operation is carried out in response to a command to open or close the washing machine door;
determining if the erroneous operation is repeated more than a predetermined number of times according to consecutive incoming commands to open or close the washing machine door; and
in the event that the erroneous operation is repeated more than the predetermined number of times, ignoring a subsequent command to open or close the washing machine door.
2. A method as set forth in claim 1, further comprising the step of: returning the door to the washing machine to an original position in the event that the error occurs.
3. A method as set forth in claim 1, wherein the step of determining if there is an error in an automatic door opening or closing operation is performed on the basis of whether or not an inversion occurs in an open/closed state of the door within a prescribed period of time after an automatic door opening or closing operation is initiated.
4. A method as set forth in claim 1, further comprising the step of: clearing the number of errors in the case where the door of the washing machine has been opened or closed manually at the time of occurrence of the errors.
5. A method as set forth in claim 1, wherein said predetermined number is 3.
6. A method for controlling the operation of an automatic door mechanism in a washing machine, said method comprising the steps of: sensing a command to automatically open or close a washing machine door;
sensing whether a failure occurs in opening or closing the door in response to the command to automatically open or close the door;
incrementing a counter indicating the failure;
determining whether the counter is equal to a predetermined number; and
failing to engage the automatic door mechanism in response to a subsequent a command to automatically open or close the door if the counter exceeds the predetermined number.
7. The method claimed in claim 6, further comprising the step of: returning the door to an original position if a failure is detected.
8. The method claimed in claim 6, wherein failure is indicated by a lack of a transition between a door open state and a door closed state within a predetermined time period following entry of the command to automatically open or close the door.
9. The method claimed in claim 6, further comprising the step of: clearing the counter if the door is opened or closed manually following a failure indication.
Thanks for using fixya.
Nov 02, 2010 | Samsung Washing Machines
Power Door Light Stays on after battery was changed by a service department
follow this to reinitialize
1. Push the “MAIN” power switch to the “OFF” position.
The “MAIN” power switch is located on the instrument panel, left of the
steering column.
2. Confirm doors are closed, lights are OFF, and the key is out of the ignition.
3. Disconnect the negative (–) battery terminal and wait 60 seconds.
4. Reconnect the negative (–) battery terminal.
5. Push the “MAIN” power switch to the “ON” position and wait 3 seconds.
6. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
is completely opened.
7. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
is completely closed.
8. Push the “DOOR R” switch to open the right door and wait 3 seconds after the door
9. Push the “DOOR R” switch to close the right door and wait 3 seconds after the door
10. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
11. Push the “DOOR L” switch to close the left door and wait 3 seconds after the door is
completely closed.
12. Push the “DOOR L” switch to open the left door and wait 3 seconds after the door is
completely opened.
13. Push the “DOOR L” switch to close the left door and wait for the door to
completely close.
With ignition in the “ON” position and both power sliding doors in the fully closed
position, the “PWR DOOR” indicator on the dash should NOT illuminate.
14. Confirm proper operation of both doors using the dash, B-pillar switches, and the
transmitter button
Aug 12, 2009 | 2001 Toyota Sienna
Whirlpool gd5thgxks01 door does not auto close
You need to level the refrigerator slightly backwards so the weight of the door closes it automatically. The front legs are adjustable, so just turn them until the door closes on its own.
Aug 05, 2009 | Refrigerators
"Close the front cover" sign even the door is closed already
On Canon copiers the close front door can be caused by other doors besides the front door.Try the fuser door an the left and the vertical transport door.Good Luck
Mar 27, 2009 | Canon imageRUNNER 400S Copier
Dryers Logo
169 people viewed this question
Top Dryers Experts
