Plasma tv is only showing half the full screen.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all do a hard reset by unplugging the TV for more than 4 hours and then plugging it back in and turn it on. If this doesn't work then there is a component failure which will require to be repaired.
The issue your TV is facing is occur due to some faults like a poor solder connection and bad capacitors right where the display panel connects the main board or a component failure on your video or DMD board. In case there is a defective failure in the screen, then complete panel replacement is required. But in the instant case it might be due to faulty video or DMD board. Either way it will need to be attended to by a technician if the reset fails who can isolate the problem and main cause of this condition by testing the device.
If the set is under warranty or any extended warranty, check it to save the cost of repair which will be imminent in case the reset fails which in any case will be around $300 for a poor circuit joint trace and fix or even more if the screen is defective or the VID/DMD fix is required. Therefore, before seeking the assistance of a technician, you should try the hard reset as illustrated above.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Aug 01, 2009
Electronic tech needs help this tv only half of picture is showing what could be the problem i wants to fix it myself
Hello Danyell,
According to the model number you provided you have a 42" Insignia plasma TV. The problem you reported with having just a blank black screen on the lower half is due to a bad lower buffer board or also called a lower scan board. The part number is LJ92-01739C and if you Google this part number you can find these online and also find some sites that may show a short video on how to replace it. Price of this board looks to be about $35. Also of note is you will find that this part number is a Samsung part number which means your Insignia TV has a Samsung plasma panel in it so the associated circuit boards will also be Samsung parts.
May 02, 2014 | Insignia 42" Flat-Panel Plasma HDTV
WHITE PICTURE
my TV has a half black & half white screen & half of the TV is showing the picture including the normal sound,what can I Do,?
Dec 11, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
Problem with the LG 42PC3D 42 in. Plasma Television Horizontal half black screen, sound is still there
Sorry this tv it is not repairable because the tv Plasma screen panel itself it is the tv problems and the causes,this tv only can be repair by replace the whole new tv Plasma screen panel itself only not practical.Because the tv Plasma screen panel are 90% inportant to the tv functions and the cost of the tv.By replacing the tv Plasma screen panel will cost the same as a new tv.
Sep 22, 2011 | LG 42PC3D 42 in. Plasma Television
VIZIO P42 plasma, half screen ok, other half showing blank
First you have to check if voltage and data are ok at the Y sustain board and the Y driver boards are not running hot. Even if you know how to replace these panels you must have a scope to adjust the v-set up and v- down. Not just a simple PNP. Trouble shooting a plasma is not a short time process to do it correctly. Please let a service center look at it for you.
Feb 18, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Philips flat screen tv
It may be a problem with a cheaper HDMI cable. If the cable is too long or if the cable is of a cheaper quality, you may be able to solve the problem with a larger and shorter "pipe"
Sep 03, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Sep 15, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Problem with plasma tv
Something in the path to drive the other half of the screen has failed or is broken. Need some basic troubleshooting information in order to be any more specific, but I've seen this problem before with NEC plasmas. If still under warranty better use it Good luck
Mar 20, 2006 | NEC PlasmaSync 61MP1 61 in. Television
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
