Water dripping from air condtioner-inside room
    Sergeant:
  • 202 Answers
Your evaporator might be dirty needs service or the drain pipe is clogged
Posted on Aug 01, 2009
Clean the internal unit's filters. This works everytime for me.
Posted on Mar 13, 2010
Dripping water from portable aie condtioner
Remove the rear cover and clean the unit throroughly. Use a can of air duster with the little hose to carefully clean the drain holes in the drip tray under the evaporator (upper radiator) let the unit fully defrost, drain the unit from the bottom plug. Clean the fins wth a toothbrush and windex if needed. Reassemble and run the unit in fan mode for an hour to let it dry out.
Jul 08, 2012 | Windchaser PAC9 Air Conditioner
Water flushed from unit inside the room instead of beeing flushed outside throw the out let pipe
Possible that the tilt is more to the front that makes the water drip down. Another reason is that the drain pipe can be clogged with dirt build up and so it flushes back.
Finally if the evaporator is dirty and clogged due to dirt accumulation the water might drip down to the front.
So please check you filter, use high pressure air on to clean and reset the panel.
Aug 27, 2011 | LG LSC121PMA Split System Air Conditioner
Where is my water drip pan located in my arctic king wall unit air condtioner? it's leaking water in the inside of my house.
it is behind the evapator unit that you see behind the filter. under neath of it is a pan it sits in. and the drain is located usually in the middle . But be certain that the unit is tilted to the outside agiout 1 inch or so.. check the filter and while your at it service it ... hope this helps let me know
Jul 23, 2011 | Heating & Cooling
My air condtioning unit is a GE unfortunately I can't se what btu but ev ry our the coil freezes and its spitting out water. Room size.
clean the coils its freezing up because the air flow is restricted because of dirty coil or filter after cleaning the coils and it still freezing up then it will need some refrigerant aka freon
Aug 19, 2010 | GE Built-In Room Air Heat Cool Air...
Carpet wet under window air con.
The air conditioner needs to be "tilted" or "pitched" to the rear. By this I mean the back (outside) should be slightly lower than the front (inside). This will allow the water to run toward the back of the unit, and drip on the ground instead of inside the house - on the floor. The A/C unit must not be level or tilted into the room (front even with or lower than the rear).
This water is the result of condensation that is created when the warm room air is drawn through the much cooler coil & fins inside the unit and is completely normal. The more humid the air inside is, the more condensation will form, and drain away.
Jul 15, 2010 | Maytag M7X05F2B Air Conditioner
The ac is dripping inside the room
Hello.
You need to clean out the drain pan.Also unit shold be tilted back a little so water will run outside.
Remove the front grill and using an old tooth brush clean out the bottom pan where water is laying.Also be sure the drian hole outside the unit is clear.
May 27, 2010 | Panasonic CW-C100AU Air Conditioner
Air condtioner not blowing enough cold air and water is dripping from the back of the air conditioner. Please help.
the coil is probably frozen hense the low airflow. This is caused by dirty filter, dirty coil or low on freon
Jul 29, 2009 | Heating & Cooling
Danby dpac120068 Air Condtioner, where does the hose go? and do you fill the tank in the back with water?
hose goes into a bucket or out a window, drained, etc. it's the drain hose for the condensation. alternatively you can use the tank to catch the condensation, which must be emptied periodically.
Jun 14, 2009 | Danby Portable Air Conditioner
Panasonic CS-12JKZW aircon leaking water.
get a air condtioning tech to do it.high voltage in side the unit.plaes call the service center of panasonice agent.
Jun 08, 2009 | Panasonic Room Air Conditioner CWXC104HU
Heating & Cooling Logo
310 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
