Question about GE Washing Machines
My ge front load dryer stops mid cycle. If I bang on the top Right above the start button it starts back up
    Top Expert:
  • GE Master
  • 83,843 Answers
Check the door switch it is likely defective
Posted on May 11, 2018
    Top Expert:
  • GE Master
  • 9,798 Answers
Or loose wire to motor or board
Posted on May 18, 2018
  • 5 Answers
SOURCE: GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Posted on Oct 31, 2008
  • 5 Answers
SOURCE: Dryer stopped working
The dryers drive belt most likely broke. it must be replaced with a new one.
Posted on Dec 20, 2008
Healeyman
  • 1198 Answers
SOURCE: Dryer stopped working mid-cycle.
I presume she pushed the start button again. Can you hear the motor running? If so, it's a broken belt. The door switch can fail anytime. If the dryer started ok later, the motor was overheated. Lighter loads will avoid a lot of problems, and the dryer will probably work better.
Posted on Apr 21, 2009
  • 91 Answers
SOURCE: Crosley Electric dryer stopped in mid cycle and will not start
if the machine is completly dead an not doing anything locate your fuse panel ,check your fuses for the dryer ,if you can find wich one is it reset the breakers again you probably popped one of the 2 lines since you need 2 for a 220v.
good luck!
Posted on May 27, 2009
  • 410 Answers
SOURCE: ge washer quits filling and spinning mid cycle
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and just happened to see that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer, a front load washer, or a dishwasher, I suggest you
go directly to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as many other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair nformation on most washers and dryers, dishwashers and many other household appliances. I think you'll find what you need there. Don't worry about the timer on a washer, they hardly ever go bad. I realize I haven't solved your problem for you, but I hope I have sent you to a place that will help you solve the problem. Good luck with it.
Posted on Dec 07, 2009
My Estate by Whirlpool dryer stopped working on 2nd load of day. Push start button doesn't do anything. Power is fine to dryer. Is there an in-line fuse or something that would have been tripped...
Yes indeed the dryer has a thermal fuse that not only could go out between cycles it could also mid cycle and leave ya with a partially dry load and a dead dryer, that is one of two parts that could be your trouble the other is the door switch, open the door and see if their is a little finger on the top right corner of the front panel inside of the door area, if not it has snapped of and the switch needs to be replaced,if its intact the thermal fuse is the problem
I have included links for youtube videos showing you how to replace the thermal fuse and the door switch
http://youtu.be/aUQQJAxkZ0g thermal fuse video
http://youtu.be/gWQhuQXa6d0 door switch video
Jul 26, 2011 | Dryers
GE dryer stops mid-cycle. If I try to restart it, it won't. Once I wait a few minutes for it to cool down, it will restart. I never know how long it run till it stops. A load last night stopped at...
I would say thermal fuse, here is a website that will tell you how to check, it also has other possibilities, Hope This Helps Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 21, 2010 | GE Dryers
My dryer has been difficult to start lately especially if stopped mid cycle. The lights are all on but it won't start up. Today I only used it 2 times and it was very difficult to start after pressing many...
You may be experiencing "Heat Retention" by stopping your dryer mid-cycle, which you should NOT ever have to do! If you have a minor vent restriction or if you open the dryer mid-cycle when the heat is on, this will cause a disruption in the airflow and rising temperatures can keep the dryer from restarting until it has been cooled long enough.
Check your vent all the way to the outside for restrictions/obstructions every 6 months. Clean your lint filter after each load and DO NOT stop the dryer mid-cycle!
Note: Stopping the dryer mid-cycle can also cause severe burns and even melt polyester fibers.
Jul 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Need to reset washer it is stuck in mid cycle and wont continue nor start over
doesnt this model have the cancel button by the start button.......if so........switch on then hold cancel for 10 seconds...........
cheers
Jul 24, 2017 | GE WBVH6240F Front Load Washer
Apr 21, 2009 | Dryers
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Dec 20, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Washing Machines Logo
752 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
