Question about Kenmore Refrigerators
The light is not working in the Kenmore refrigerator. I changed the bulb but that didn't fix the problem
  • AKINYINKA OLAWUNMI
    AKINYINKA OLAWUNMI May 27, 2018
    Did you use the right bulb with the right voltage and amperage?
    Do also gheck the cables for continuity.
  • Kenmore Master
  • 3,462 Answers
Could be the door switch, that is the most likely.
Other than that, use an electrical tester and test the socket itself. God bless your efforts.
Posted on May 11, 2018
4 Suggested Answers
peyton32034
  • 410 Answers
SOURCE: Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Posted on Dec 12, 2007
  • 1082 Answers
SOURCE: The rear turn signal lights
You need to change the flasher unit. Usually a silver squat cylinder with a 3 prong connection.
Consult your owners manual for the location of the flasher module. It is likely under the dash maybe clipped the the body / frame work there. Note that here are usually 2 of these. one for the signals and one for the hazard flashers.They are interchangable. These are only a few dollars at any auto parts store.
Posted on Jun 21, 2011
Macmarkus
  • 2605 Answers
SOURCE: The freezer is functioning properly.
Hello, welcome to FixYa.
Based on your post I understand you have a problem with a Frigidaire refrigerator, model: FRT17HB3J...
, however if I could verify the later part of your post.
When you replaced the bulb did the light still not function ? Also before you reply I'd suggest you verify the fan in the freezer is operating as the only thing the fridge section depends on to remain cold (provided the unit is operating which obviously it is if the freezer is cold) is the fan in the freezer moving air to the lower cabinet/fridge section.
This unit doesn't even have a damper to fail to open, it's just straight blow through cold air. If you could let me know as much info the better I would then be better equipped to assist you without generalizing on what it may or may not be. I'll watch and look forward for your reply and we can go forward from here.
Thank you for visiting FixYa for your inquiry.
Regards,
Macmarkus :)
Posted on Jun 26, 2011
Why don't the lights come on on either side?
  1. How To Fix Refrigerator Light That's Not Working ' Fridge ...
    www.partselect.com/Repair/Refrigerator/Light-Not-Working/
    Troubleshoot the common reasons why the refrigerator light won't turn on. Checking the bulbs or lamps, inspecting the light socket for damage or discoloring.
Jul 10, 2015 | Kenmore Refrigerators
How to change light bulb in Kenmore refrigerator serial no. 4A31214613 ?
Open freezer and reach to the back of the plastic cover over the light. You'll feel a gap in the back center of the cover. Gently pull forward and the cover will drop down and pull to the back to fully remove it. Once you've removed the cover you can unscrew the bulb, which you can use to make sure you purchase one like it and most hardware stores, such as Ace or Home Depot. Reverse the removal instructions to install light and cover. Light should turn on once you've screwed it in.
Jul 22, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Model number ffhs2313lp3 light burnt out got a new one wont work
if you new light still didn't work . so what's the problem ? maybe the light was in good condition . did you check you circuit board ?
home light bulbs
May 31, 2012 | Frigidaire Refrigerators
Both of our light bulbs on top burned out the same time/day. Model # GLRT218WD My husband changed one light bulb and it didn't work. Does that whole piece come out of the top, where the light bulbs...
Check the door switch. Alot of the time when the freezer door stays open it creates condensation and than when you close the door is can freeze the door switch closed so the switch thinks that the door is always closed. If you need further assistance or this does not cure your problem please reply.
Aug 01, 2011 | Frigidaire Gallery GLRT218WD Stainless...
How do I change the light bulb? I twist and pull but nothing happens. I have a Kenmore 106.72864100.
Is it the cover or the light bulb that isn't coming out? The cover for the 74889 needs to be pushed up and then pull it forward and down. It is hanging by a tab that holds until the angle of the cover is changed to a shallow angle relative to the back of the fridge. The light bulb should unscrew by turning it counterclockwise. If the bulb was previously overtightend, then you may need to use something to improve your grip on the bulb. I sometimes use the plastic jar opener sheets. If the bulb breaks, remove the remainder of the bulb from the socket with pliers (I use needle-nose or similar long straight blade pliers held open to the width of the butlb).
You should unplug the appliance while changing the bulb.
The manual for the Kenmore 74889 is available here: http://www.managemylife.com/mmh/owner_manuals/5899/KENMORE-Top-Mount-Refrigerator-L0411041?brand_name_search=Kenmore+74889 . Other Kenmore manuals can be found by using the search engine here: http://www.managemylife.com/mmh/owner_manuals .
I hope this helps.
Mar 21, 2011 | Kenmore 74889 / 74882 / 74884 Top Freezer...
How to change a bulb in the Kenmore refrigerator
Most likely, you never notice the light bulb in your freezer or refrigerator until it is not working. Then it is time to replace the bulb. This is especially important with freezers, which are often in areas with poorer lighting, like basements or garages. Fortunately, the task is a simple one.
Instructions
1 Unplug the freezer to prevent an accidental shock when you remove the light bulb.
  • 2 Open the door of the freezer, look at the top inside edge of the freezer, below the door seal and back about 1 to 2 inches from the edge. You will see a small plastic or metal panel that protects the bulb from damage and shields your eyes from the direct light of the bulb when the door is opened. Reach behind the guard and remove the bulb by twisting it to the left.
  • 3 Put your new bulb in by inserting it into the socket and twisting it to the right to screw it in. Be sure you use a freezer bulb--it is built a little tougher and is the correct wattage. You can find them at appliance or hardware stores. Plug the freezer back in to test operation of the bulb.
  • Have a nice day! : ))
    Jan 30, 2011 | Kenmore Refrigerators
    The light won't work, I changed the bulb and it still will not work
    Probably bad door switch. Look for a roughly triangle shaped piece of plastic that goes into its housing as the door closes. This is the door switch. Probably a similar one at the freezer door too. Snap this switch a few times with a good bulb in place. If bulb lights even once it is the switch. BE SURE BULB IS GOOD by trying it in a room lamp first.
    Door switch can be pried out using a dull knife around the plastic. Do this with the power cord unplugged. Switches like this are common to many Kenmore or Whirlpool models.
    Sep 09, 2009 | Kenmore Refrigerators
    Side-by-side Refrigerator Door Exterior Light has shortage
    the base of light bulbs vary from different manufactures and sometimes they do not seat all the way. unplug your refrig and try to look into the lite socket. you will see a brass tab in the bottom of the socket simply use a small pick or flat tip srew driver and pull the tab down a little bit then reinstall the bulb plug the fridg back up and it should work. thanks peyton
    Jan 19, 2009 | Kenmore 53642 / 53644 Side by Side...
    Refrigerators Logo
    764 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    ka4iup
    ka4iup
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
