Question about LG WM-2277HW Front Load Washer
I have the LG Tromm, WM2277HW. I followed the
I have the LG Tromm, WM2277HW. I followed the solutions and ordered the part as suggested. The instructions were very easy to follow and I changed out the sensor. Keeping my fingers crossed, I ran an empty load, all seemed fine at first then it threw the LE code again. Im at my wits end. Repair service said I should throw it out (bought it 8/04. They estimated almost $1,000 to fix it!! I know it's not the motor as I just had it replaced as the repair first told me that was the problem.
Someone please help. This machine was not cheap and should last more than 5 years, trying to fix it as no repair people know what they are talking about.
I took the entire washing machine apart. I checked the drain pump as the repair service said I needed a new one, as well as a rear and front drum, shocks rear bearing assembly. Would you believe the only thing wrong with the unit was that the drain pump was clogged at both ends. Machine is running fine and not throwing the LE Code. The repair service (LG recommended dealer) should be shot for telling me to throw out the unit.
Posted on Aug 03, 2009
My lg tromm washer on the wash cycle is not spinning, and is making a grinding noise
check for something in the bowel. pins ,buttons coins etc have a technician check the spin operation.
Mar 03, 2015 | LG 4925ER1015B 4924ER1010 Used Frontload...
WM2277HW LG Tromm washing machine won't start. Finding correct parts is not so easy. Why?
At 14+ appliance years of age, it doesn't make economic sense to repair it.
Mar 06, 2017 | LG WM-2277HW Front Load Washer
"LG Tromm WM2277HW will not
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
My LG tromm wm2277hw front loader just turned off, can it be a switch, there's power in the outlet, no lights, circuit board is off, no water underneath, dryer is ok plugged in the same outlet,
That could very well be the line voltage suppressor (called a noise filter) that is built into the washer. Take the top off and follow the power cord into the machine. It connects to this component. themobilian_17.png
PAGE 22
Feb 06, 2011 | LG WM-2277HW Front Load Washer
LG Washer Model #wm2277hw
It is a motor error
• The connector in the LEAD WIRE ASSEMBLY is not connected to the connnector of STATOR ASSEMBLY Reconnect or repair the connector • The hall sensor is out of order/defective. Replace the STATOR ASSEMBLY
Apr 19, 2010 | LG WM-2277HW Front Load Washer
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
LG Tromm WM2277HW OE error message
unit not drainning..in the but front left hand corner ,,there a panel,,open panel and clean your filter...onthejob...
Jan 25, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE error
try using a-fresh its should help you out.
Oct 12, 2008 | LG WM2688HWM TROMM SteamWasher
Tromm Washer Model # WM2277HW by LG
will it spin after it washes if it does not then your belt might be broke
Feb 12, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
741 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
