Question about Ryobi Garden
Were do the fuel lines go - Ryobi Garden
Remove fuel lines from fuel pump housing
You may need a fuel line tool that compresses a spring in the collar. You can get them at any auto store..
Apr 28, 2013 | Cars & Trucks
Replace fuel lines on model no. 358.797931
Hi.
Before you remove any fuel lines, make a drawing or take a picture of how the lines are connected to the tank for later reference.
You will need to remove all the old fuel lines and fuel filter out of the gas tank.
Clean and remove all trash, broken lines,etc. from the fuel tank.
After you have all the trash,fuel lines and filter removed.
You will trim the end that goes into the fuel tank to a point.You will lubricate about 1 inch of fuel line with a small amount of vasoline or light machine oil...
Now using your fingers or small needle nose pliers push the fuel line and insert it into the hole in the fuel tank.
After you have the fuel line in the tank, extend enough fuel line into the tank to exit the fill spout of the tank .
You will insert the new or cleaned fuel filter into the line and pull the fuel line to pull the filter just back into the tank.
Hook up the fuel lines to the carburator and you should be good to go
Please take time to rate me
Bud
Apr 21, 2013 | Garden
How to change fuel lines
There should be only 2 fuel lines and a vent line coming out of the tank. The vent line is for fumes that are routed to the charcoal canister-part of the evaporative emissions system, and the two fuel lines are the main feed line to the filter and then on to the engine, and the other gas line is the return line from the engine back to the gas tank. All fuel injected systems have a feed line and a return line. The return line is for fuel not used but sent back to the tank by the fuel pressure regulator.
Nowadays, rather than replace metal lines, shops can use the plastic fuel lines (they don't rot!) and special connectors to fit new fuel lines. YouTube has lots of videos on replacing fuel lines.
Apr 23, 2017 | 2004 Buick Rendezvous
How do I replace a broker fuel line? The one broken has a filter inside the tank.
Hi doug c197...
I will also include a fuel routing drawing.
After you have all the fuel lines and filter removed.
You need a piece of wire...smaller diameter than the inside of the fuel line, insert the wire into the fuel line until it exits the fuel line then bend a hook on the end of the wire to hook over the fuel line.
Now using your fingers or small needle nose pliers collapse the fuel line around the wire hook and insert it into the hole in the fuel tank.
After you have the fuel line in the tank, extend enough fuel line into the tank to exit the fill spout of the tank and remove the wire from the fuel line.
Sep 24, 2011 | Garden
Have 2 gas lines dangling in gas tank, mcculloch 42c, 36cc, older, one line has filer other for primer????? or did it come disconnected
Hi perfecthelme...
Those are broken fuel lines your are seeing and a fuel filter inside of the tank
I will include a fuel routing drawing.
Clean and remove all trash,broken pieces of fuel line,etc. from the fuel tank.
Fuel line in tank dry rotted how do you replace
Hi classic11369...
Remove the old fuel line and filter from the tank...
You will insert a wire a little smaller than the diameter of the inside of the fuel line, and you will bend a small hook on the end of the line to fit over the fuel line (be sure to use a small wire) .
Lubricate the first 1 inch of fuel line with vasoline lightly...using your fingers or neednose pliers collapse the fuel line and insert it into the fuel tank, entend the fuel line long enought to go out of the fuel tank so you can reconnect the fuel filter...then pull some of the fuel line back into the fuel tank...
Please take time to rate me thumbs up
Sep 23, 2011 | Homelite ZR10926 16" Chain Saw
How do i remove the fuel delivery and return connectors at the engine
go by the auto parts store, buy fuel line disconnect tools.you take the fuel line disconnect tool, place it on fuel line push tool in the fuel line connector to seperate fuel lines.make sure when you get ready reconnect fuel lines back together you should hear fuel line snap back in place.make sure fuel line in place dont come apart. to be on safe side dont crank car first just turn ignition to the on position for few seconds check for fuel leaks.
Jul 31, 2011 | 2000 Buick Century
Need to replace all gas lines
  1. Empty the fuel tank on the chainsaw of any remaining fuel. Pull the cap from the tank and turn the unit upside down. Drain the fuel into an approved fuel container. If the fuel is old (more than about a year) dispose of it according to local regulations for hazardous materials. (It can be kept longer by adding a fuel stabilizer.)
  2. Pull the fuel line where it attaches to the carburetor using the end of the needle-nose pliers. The old fuel line may take some force to pull free from the metal tube.
  3. Push on the fuel line to feed it into the fuel tank. Hold the chain saw upside down. Shake the unit to get the fuel filter into the opening of the tank. Pull the filter free of the tank. Feed the remaining fuel line through the access hole at the bottom of the tank. Dispose of the filter and old fuel line in accordance with disposal regulations.
  4. Feed one end of the new fuel line into and through the bottom access hole of the fuel tank. Push approximately 6 to 8 inches into the tank. You can pull back any excess line later. Grab the end of the plastic line with the needle-nose pliers. Bring the line through the gas tank fill opening.
  5. Attach the new filter to the end of the new fuel line. Feed the filter back into the fuel tank. Pull any excess line from the tank. You will want approximately 3 to 4 inches of fuel line inside the tank.
  6. Route the new fuel line to the carburetor. Cut the line to length with the cutters on the needle-nose pliers. Attach the line to the metal tube.
  7. Fill the fuel tank with fresh gas-oil fuel for 2-stroke engines and start the chainsaw. It may take a few pulls to prime the new line with fuel.
  8. Some models come with a priming bulb. Make sure you press the priming bulb three to four times before trying to start. This will prime the gas lines and remove any excess air trapped in the lines.
Nov 15, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
My Toyota Sienna keeps stallling
If the car stalling then the owner of the car should check on the fuel pump assembly. prepare the tools and equipment in servicing the fuel pump,the fuel lines and the fuel filters.In the fuel pump you have to locate the fuel pump,disconnect fuel lines from the fuel pump,remove fuel pump from the engine,dis-assemble fuel pump, check the diaphram for defect , replace defective parts,assemble and install the fuel pump.
In checking the fuel lines : prepare the tools or equipment in servicing the fuel lines .So that the fuel will flow freely and no abstraction within the fuel lines.locate the the fuel lines ,visual inspection on dual line for leakage, disconnect lines at fuel pump and fuel tank .use compress air to remove sediment on fuel lines,re-install fuel lines to the unit.
the fuel filters :prepare the equipment or tools in checking the fuel filters that is going to be used.So that when fuel filters is removed ,no fuel will spill on the vehicle and no parts are lost or broken.Locate fuel filter,disconnect lines at fuel filter ,observe safety practices ,If the fuel filter is dirty then you have to clean it but if it is worn out and not anymore to be used then install new fuel filter.
Sep 24, 2009 | 2008 Toyota Sienna
Finding were a filter is
On these vehicles, the fuel filter is located on the fuel line to the carburetor. Special care should be taken when removing and installing the fuel filter, not to bend or distort the fuel line in any way.
  1. Remove gas cap to relieve any pressure that may be present in the fuel system.
  2. Remove the air cleaner bonnet assembly.
  3. Using a backup wrench on the return line fitting on the top of the fuel filter, remove the fuel line with a flare nut wrench.
  4. Using a backup wrench on the fuel filter inlet fitting, remove the fuel line from the fuel filter with a flare nut wrench.
  5. Using a backup wrench on the fuel filter outlet fitting, loosen the fuel line and remove the fuel filter from the engine with a flare nut wrench.
To Install:
  1. Apply a drop of engine oil to all the fuel line nuts and flared ends.
  2. Position the fuel filter with flow arrow on the filter directed towards the fuel line going to the carburetor.
  3. Finger-tighten the fittings at the fuel filter outlet, inlet and return line into the top of the filter.
  4. Using a backup wrench on the fuel filter fittings, tighten the fuel lines in the following sequence:
    1. Tighten the outlet and inlet line nuts to 15-18 ft. lbs. (20.0-24.0 Nm)
    2. Tighten the nut on the return line at the top of the filter to 6-9 ft. lbs. (15-18 Nm).
  5. Inspect the fuel lines and carefully adjust if they are interfering with the carburetor, air pump, or fuel filter housing.
  6. Start the engine and check for fuel leaks at all the connections. Retighten if necessary.
  7. If removed, install the air filter bonnet assembly.
Jul 26, 2008 | 1993 Ford Tempo
Garden Logo
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
