Question about Garden
The engine starts well, but runs unevenly.....slow fast, slow fast. there is no throttle as far as i c`an see....any ideas?
    President:
  • 1,486 Answers
Remove the fuel bowle from under the carb.And clean the jet.
Posted on Aug 01, 2009
What is wrong with it?
the throttle cable has been adjusted to far foward making choke engagement hard and the govenor speed needs to be adjusted down it set to fast
Jun 06, 2014 | Husqvarna 21" Lawn Mower with Honda GCV160...
Uneven idle while running and in park but no check engine light
The idle air control motor is dirty. It's mounted on the throttle body. Clean the plunger and spring with brake clean, you clean use a soft wire brush or tooth brush. Also clean the hole it came out of. Wouldn't hurt to use the brush and clean as far as you can in the throttle body. It will take a second or two to start after you do this, Then run normal afterwards.
May 02, 2014 | 2006 Chevrolet Silverado 1500 2WD
Why does my 2006 chevy silverado 1500 5.3 ltre have an uneven idle when running and in park. no check engine light.
You need to clean the throttle body and the idle air control motor. Use brake clean and a toothbrush. Clean inside the throttle as far as you can and clean especially the back of the throttle plate and where it sits when it is shut. It's best to remove the Idle control motor and clean it with the brush. But you can start the engine and clean it some by revving it up and spraying into the throttle around the hole for the motor. It will take a second or two to start after cleaning.
Engine runs fast and slow
Take a spray of carb cleaner and clean the linkage mechanism from the governor to the carburetor and make sure they move with out sticking.
Dec 07, 2013 | Briggs Stratton Portable Generator 305cc...
Hi guys...my yaris is running rich, has poor gas mileage (360km on a full tank). and very slow and choppy idle (idles like a really old car) these are the things i have done so far : change air and fu
Do the following:
1. Clean the throttle body from inside.
2. Adjust the spark plugs gap to 1.00 mm.
3. Check fuel pump pressure. (44 Psi - 49 psi)
4. Remove the negative battery terminal for 5 minutes.
5. Connect the battery terminal.
6. Check the engine oil level and coolant level.
NOTE: Before starting the engine shut off all lights and loads for example room light, blower, radio, parking light etc.
7. Start the engine and hold the throttle at 3000 rpm till radiator fan comes on.
8. After the fan comes on release the throttle pedal and let it idle for 10 minutes.
May 08, 2012 | 2005 Toyota Yaris 1.3
Volvo v40 2000nx reg 1.8 NON gdi engine constant high rpm can having no thermostat cause constant high rpm or can a briken lambda sensor cause high rpm cleaned all throttle body cleaned idle valve checked...
Yes, having no thermostat can cause the car to run fast as it will still be set in it's "warm up" mode and will be injecting a richer mixture of fuel/air into the cylinders. There may be an additional cold start injector that just works while the engine is cold. You will probably use more fuel like this. It's not a great idea to run with no thermostat anyway because you get uneven hot and cold spots around the engine which is bad for it. Cheers
Feb 06, 2012 | 2000 Volvo V40
Fast idle astro van
Check the base plate gasket under the throttle body, some time the gasket start to leak, and will cause a high idle, if possible with engine running get some water and pore it at the base of the throttle bode, you will hear a suction sound, that's the gasket, replace it.
Jul 14, 2010 | 1995 Chevrolet Astro
Engine starts fine however it runs fast and then slow, fast, slow all the time it's running....what is that?
It is called oscillating, The carburetor may need adjusting or it could be caused by bad fuel. Manufacturer's school this year have told us, at every school, fuel over 30 days old is considered bad gas and needs to be replaced. You may even have a throttle or governor spring that needs replacing.
Good Day.
Oct 09, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Craftsman ys 4500 throttle kill switch?
if you push it that far you are choking the motor
back the throttle back down to slow and try to start the mower if it starts go back to fast but not all the way to choke
Apr 22, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
My rear tine tiller lurches out of control when I use it
Hi it sounds like you are trying too till the soil with the tiller in the fast position and probably too deep for your first pass. Really the fast position is for transporting the tiller from the field. Try putting the tiller in slow which would be the down position. Turn the throttle all the way foward, engage the tines and push your depth rod on the back down to where it is only going into the soil about four inches or even less depending on the hardnes of the soil. Even though a Troy is the best Tiller made it will try to run away with you when your trying to hog the soil all at once. Your depth setting is very important and people seem to forget the importance of adjusting it. Try these things, and remember to alway's start your tilling in the slow full throttle position. Lowering your depth a little at a time. Till you find the appropriete feed for your speed.
Jan 07, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Garden Logo
214 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
