Question about JVC AM FM CD DET FACE CAR STEREO
Sam exact problem
All fuses are fine as well as the wires
not sure what else to do...
  • 43 Answers
Try to reset the deck there should be a small button about the size of a pen tip on the face or if you take the face off the unit, if that doesnt work i would say its the ribbon on your deck that cut its self
Posted on Aug 05, 2009
No power to the A/c compressor 2003 mercedes c230
Are you sure? It is not fused and is feed directly from the front SAM(N10/1). Look for a blue wire with a green stripe that is all alone to a small connector at the front SAM(fuse box). Check for power at the SAM on that pin. If there is power at the SAM then the wire is either broken, you used a bad ground for testing or the ground may be bad. You can always ohm out the wire to make sure. it is the correct wire and it is not broken.
Oct 11, 2013 | 2000 Mercedes-Benz C-Class
I have mercedes s320 cdi 2001 and need to know which sam module unit controls the dash lights and instruments/gauges would be grateful for any help
Go to manualsonline.com Then in the search window type in Mercedes-Benz 2001 S class. Then go to page 156-157-158 and so on till you find exactly what you need. You can also go to the index in the manual if I miss understood what you are needing. Hope that Helps!
Sep 03, 2013 | Mercedes gl 320 cdi control unit sam. ....
Nissan Xterra Brake Light Fuse Location
Hi, you need to test if the power is coming to the plug for rear brake light. If the power is not there that is your first problems. Also may have earth wire problem.
Jul 20, 2013 | Nissan Xterra Cars & Trucks
Great white trolling motor,bow mount,24 volt, 82lb thrust / big problems! Burned up Marinco plug,replaced plug,recetacle,fuses on. batteries, tech says motor runs fine on bench,but not on boat. Getting 24...
The heat is developed from to much resistance from batteries to TM, check for loose/corroded connections at batteries, including the jumperwire, also check the size of wire from battery to plug, should be at least 8 gauge if not 6 gauge depending on the length of run. If corrosion has built up inside the wires this will also cause high resistance causing excessive heat build up. I would prolly just replace boat wiring to make sure none of the above problems are present. Use tinned copper marine grade wire that is multi stranded.
Mar 08, 2012 | Boating
Dash illuminates when key is inserted, but when turned to start position ,the car starts and drives, but you lose indicators,wipers, rear brake lights,electric windows . there is a yellow 20 amp fuse in...
It wold be the faulty SAM according to my knowledge your technician have told you what's wrong in it. must check the front SAM and rear SAM as well,
Jul 15, 2011 | 2002 Mercedes-Benz C-Class
I have a mercedes-benz clk 270 cdi avantgarde and the other day the battery light/visit workshop came on....poly v belt replaced, but the warning light still on......any suggestions??
YOU NEED TO ERASE TROUBLE CODE WITH A CODE SCANNER.IF CODE HAS BEEN ERASED AND WARNING LIGHT STILL APPEAR MAKE SURE ALTERNATOR BATTERY POWER FEED WIRE AND CHECK WIRE COMING FRONT SAM CONTROL MODULE WITH FUSE AND RELAY MAKE SURE WIRE IN PLACE TIGHT NOT DAMAGED. CHECK MAIN FUSE IN FUSE BOX THAT SEND POWER TO STARTER AND ALTERNATOR.
Jun 28, 2011 | Mercedes-Benz CLK Cars & Trucks
I turn on my monitor and it works fine for about a minute then i lose the screen. It a vision quest monitor and I'm using it as my second monitor but its hooked up to monitor port 1 on my tower.
The problem is most likely the power cord if this is an LCD screen. They need a specific amperage and if it is just a little off it will do exactly what it does, powers up and then shuts down. Check specifics on the back of the screen and make sure the power supply matches. I had exactly the sam problem on a monitor, I got the right power supply and fixed the problem.
Nov 28, 2008 | Computers & Internet
Fuse 8 blows, dome lights
There is no relay, you have a short in the system, I have fixed dozens of dome light problems on the Taurus and it was seldom the same problem from car to car, check the door switch wires first, remove the switch and diconnect it, if the short goes away the wiring is shorted to the door switch. I am sorry but there is never easy solutions to this kind of problem.
Aug 26, 2008 | 1995 Ford Taurus
Missing speaker wire for Samsung HTSK5 reciever
check the nearest best buy I am sure you can fine compatible wire that will fit. Or any music store such as Sam Ash music store I am 99.9 percent sure you can find it to Sam Ash music store.
Good luck
Jul 22, 2008 | Samsung Audio Players & Recorders
JVC AM FM CD DET FACE CAR STEREO Logo
108 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
