Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
My VIP 622 dvr was struck by lightning via the telephone line. It s not turning on any more What can be done to bring it back to live?
  • 4,806 Answers
I'm sorry to tell that there is probably nothing you can do as a lightening strike will have no doubt fried the electronic components inside the unit.
The only thing you can try and it's not guaranteed to work is to unplug the unit from the wall and leave it off for a couple of hours to see if the unit will reset, also make sure you reset your surge protectors if you have any.
Regards.
Posted on Aug 01, 2009
Problem synching panasonic dvd audio sync with dish network video
Try to run the audio through the TV. through the audio out on the TV. if it has one. For example run the HDMI to the TV. then use the audio output of your TV. to your DVD/Receiver.
Mar 18, 2013 | Televison & Video
Is this resiver HD ?
am_witek,
Our 625 receiver is not an HD model. Our current HD models are ViP 211/211k, 222, 612, 622, 722/722k, 922, and our Hopper receiver.
If you have any other questions, let me know!
Tommy Faust
DISH Social Media Representative
Nov 24, 2012 | DISH Network DVR-625 DTV Receiver /...
Can you record a program and watch live TV at the same time?
If you have a dual receiver, you can record to TV 2 and watch any program on TV 1. If you have 2 recordings taking place at the same time, you can only watch what is being recorded.
With a dual receiver, you can place the receiver in single mode and watch a different program even if 2 recording are taking place. In single mode both TV 1 and TV 2 will be watching the same program.
A solo DVR you can record to tuner 2 and watch what you want on TV 1. With the VIP 622 receiver, you have the Record Plus option, you can have all recording go to TV 2. If 2 recordings take place, then TV 1 and TV 2 are used.
Jun 29, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Receiver vip 622 problem with dvr
Hello marymlbert there are some things we can check to makesure the issue is resolved, the first thing you will need to do is unplug thereceiver power cord for 10 seconds and plug it back in. It will power back upby itself and then you will need to press Menu and push the buttons 6-1-1 onthe remote. You will then select the Check Switch button, and then select Test.After the test has run its full cycle exit out of all menus and then try toplay a recording and see if the issue is resolved.
Mike Houston of DISH Network
Jul 12, 2010 | DISH Network ViP622 DVR DTV Receiver /...
If I don't have a cable or satellite television service how to install a VIP 622 DVR HD Antenna
Mount the dish on a pole or house using a mast perfectly plumb. Ensure it will give you an unobstructed view of the sky based on the information that should have come with the dish regarding your zip code for skew, elevation and azimuth settings. You will now need to run one line from the LNB on the end of the skew arm to your 622. Remember to use a seperater inside or you will need to run another line into the back of the receiver. Run a hardwire off back of the receiver's home distribution port to . Connect a line from 3-4 on back of the receiver to your TV 1. ....More to come if needed drop me another line.
Thanks for using Fix Ya.
Jim
Feb 13, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Dish 622 freezes up
You have a hard drive failure and will need the unit replaced. Thanks for using Fix Ya.
Jan 29, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Phillips dvr won't power up. Lost power at house
Try hooking it up to another (working) electrical outlet. If that doesn't work, there's several possible problems.
The most likely is that the box was fried when a larger-than-usual current traveled down the line (or even down the coax if lightning struck and your system isn't adequately grounded); the electrical outlet is either pushing too much or too little power; or your house's ground polarity is reversed.
More than likely your box is bad. If you don't know very much about electrical systems, don't go messing with your ground or any outlets without a wall plate.
Dec 26, 2009 | Philips DIRECTV R15
I lost 60 hrs. of recording time in less than 24 hrs. on VIP 622
Remove all the External Storage devices, make sure that you Un-Plug them Completely including their Power. After Resting the Dish Receiver, Plug-In everything back on and try.
Mar 16, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Connecting a Dish 622 Receiver to the HTR500 and a Sony HDTV TV
I haven't researched to actual manuals for your equipment, but I'm guessing that the optical may be disabled when the HDMI is used. You could try using the component video outputs to the TV and then the optical to the Onkyo.
Jan 02, 2008 | Onkyo HTR500 Receiver
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
108 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
