Question about Black & Decker Lawn Hog 18-Inch 12 Amp Electric Mulching Mower
Lawnmower blade turns but does not cut - Black & Decker Lawn Hog 18-Inch 12 Amp Electric Mulching Mower
    Problem Solver:
  • 7 Answers
Maybe you installed the blade upside down.
Posted on Sep 30, 2015
    President:
  • 1,486 Answers
You have either bent the blade and its to high to cut or you need to sharpen the blade with a grinder.
Posted on Aug 01, 2009
My poulan pro lawnmower blades are not cutting when running
Are your blades installed up side down?
Is the blade drive belt installed properly or are the blades turning backwards? Is the belt too loose and slipping?
Are the blades dull and need sharpening?.
Oct 04, 2014 | Garden
How do I replace lawnmower blade
Usually a 3/4 inch. Use a block of wood to jam the blade in the chute. Then turn the nut in the same direction of the cutting edge of the blade
Aug 17, 2014 | Garden
My electric lawnmower sometimes does not start, just humms. Then I TURN IT OVER, AND TURN THE BLADE A LITTLE BIT. the blade feels hard at first but soon feels loose. then it wil start as normal
The lawnmowers electric motor has a bad spot on the armature. You need to replace the electrical brushes that contact the motor. If you are lucky you may just need to clean them and reinsert them in to brush holders.
Nov 25, 2013 | Electric Lawn Mower
I have a florabest electric lawnmower, the blades are turning and were sharpened recently but it is not cutting the grass...any ideas?
check that the blades were put on correctly and the sharp side is in the right position . if not then the blades are trying to cut the grass on the back side un sharpened side.
Jun 02, 2013 | Garden
Hi, i have a BSA ECCO16 petrol lawnmower, and I have been looking for a replacement blade for a few months, the blade I have at the moment is a power devil 16'' blade with tails, it is cutting
talk with a mower shop
from your description you have a solid bar attached to the hub on the crankshaft with a cutter blade at either end
the cutter blades should have the rear section turned up to create an air flow to throw the gras out the back
you can replac the single blade with a disc that has 4 blades each turned up at the back and that makes cutting easier and a higher rate of discharge out the abck
May 12, 2017 | Garden
I have an older Black & Decker electric lawnmower
Does the mower sound like it is running at full speed? Have you double checked that the blade was not installed upside down?
Aug 06, 2011 | Black & Decker Garden
Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
Aug 22, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
I have a husqvarna 172 ride-on lawnmower. Running
This unit probably has a safety switch built into it and it could be below the gas tank. If this switch isn't adjusted properly then it's designed to cut off the motor. I think you should concentrate on that before attempting anything else.
Aug 02, 2009 | Garden
Swisher lawnmower wont mow
Yes It would. The belt doesn't just wear it slackens also. It will probably turn the blades when not under load but as soon at it attempts to cut grass there is not enough grip.
Replace the belts first and it should be fine.
Regards
Marc
Apr 17, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Black & Decker Lawn Hog 18-Inch 12 Amp Electric Mulching Mower Logo
250 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
