Question about LG DLG5932W Gas Dryer
My DLG 3788W dryer does not heat.
I get a check filter light which goes out when a cycle is selected and dryer is turned on.
When I run the diagnostic test, I get the following codes:
19:F1
U01
Thank you in advance for any help you can give me!
SOURCE: LG DLG 3788W not heating
can you look in one of the holes in the back and see if the inside glows orange after you turn it on? If it doesn't could be the igniter, if it does glow orange, clicks or clacks, and glows again 20-30 seconds later, click/clack and nothing, it's probably the gas valve. I'm going through the same thing with a new one and they had to order the valve and a new controller board in case it is bad too. If you are handy, have an electronic tester, and have the patience, go to http://136.166.4.200/contents/Laundry/DLG3788.htm for the service manual and disassembly instructions and see if you want to tackle the test flow for no heat. I just stumbled on the site.
Posted on Dec 05, 2007
  • 210 Answers
SOURCE: dlg 3788w-7.3 cu ft gas dryer
You don't, it is gas dryer, so I advise you to get a authorized gas technician to look at your unit.
Chances are the blower assembly is out of whack, maybe the motor is off its brackets.
Sgt 48
Posted on May 31, 2008
MNTECH
  • 1543 Answers
SOURCE: front load gas dryer lg model dlg 5988w does not heat
This can obviously be several things, but I would first check the small safety thermostat. On the gas models, there is a small pin sticking out of it which can be pushed back in to reset it. It is located on the heater housing and is only about the size of a dime, with two wires on it. This will trip out easily if your vent was not clean, or is long or restricted in some ways (like using flex ducting)
If you need more help getting to it, let me know and I'll give you more instructions.
Posted on Dec 22, 2008
heatman101
  • 43501 Answers
SOURCE: My dryer doesn't seem to function properly, it's
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 26, 2010
heatman101
  • 43501 Answers
SOURCE: LG DLG 2526W dryer running but no heat
heatman101
Posted on Jan 15, 2011
DLG 3788W Dryer
could be the drum wheels
May 04, 2013 | LG Dryers
My frigidare affinity dryer is only starting on delicates and touch up, nothing above that
Hi.
If machine runs only in low heath cycles, then there is a problem with timer control, low heath selector, or heating assembly (cycling thermostat).
The first thing to do would be locating the tech sheet. The sheet is tucked inside an envelope located inside the control panel assembly. In the tech sheet you will find instructions to run a diagnostic cycle. The diagnostic cycle will return an error code that will help locating the fault.
With different Frigidaire Affinity dryers you need to press and hold Pause Cancel and SELECT for about ten seconds, then leave, put selector to NORMAL, temperature selector to HIGH HEAT and press START to run the diagnostic cycle. The procedure for this specific model is described in the tech sheet.
Nov 19, 2011 | Dryers
My dryer doesn't seem to function properly, it's just blowing cold air. I had it on for over one hour, my clothes are still wet and the air is still cold. The dryer model is LG Tromm DLG 3788W. The...
heatman101
Dec 24, 2010 | LG Dryers
heatman101
May 22, 2010 | LG D2526 Gas Dryer
No heat, but dryer runs
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 27, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Turning no Heat, clean filter lights on while turning
usually heat element or high and low limit sensors need changing, check vent lines are not plugged or 220 breaker if split breaker is only tripped on one side?
Jul 25, 2008 | Frigidaire FEQ1442ES Electric Dryer
Dlg 3788w-7.3 cu ft gas dryer
Sgt 48
May 23, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Dec 03, 2007 | LG DLG5932W Gas Dryer
LG DLG5932W Gas Dryer Logo
96 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
