J
John Ross Posted on May 11, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On my pd3000a receiver I have two subwoofer rca jacks but I have a sub volume control so can I still hook up pqa4100 poweramp this is all pyle equipment, please give detailed answer
Mark Cheong
Level 3:
Master:
  • Master 791 Answers
  • Posted on May 11, 2018
Mark Cheong
Master
Level 3:
Master:
Answers
791
Questions
0
Helped
476251
Points
2475
First, I'm not a Pyle tech. But back in the day I used to be an audio freak (1970's 4 channel all-the-way!)
* I tried to get the exact specs on your receiver but I suspect it's a non-amplified output. RCA jacks almost never have a high level output. (yes, the old 1940-60's used RCA jacks for speaker high level output. But you have a late model receiver.) Most likely you need a separate amp to power the sub woofer (unless it has it's own power amps.) You may still use another audio amplifier if you have a spare (mono or stereo won't mater as you only use one channel) but be aware that low frequency use way more power than normal frequencies (600 to 3KHz) The low end (50 to 300 Hz) will burn out any speaker and amp as the lower the frequency it's like hooking up a car battery directly to the speaker! If you have an old style vinyl record player that's playing a warped record. watch the speaker flap around to the wave of the record. Need to turn on the 50 Hz cancel out button to prevent speaker blowout!
* This link is still for a powered woofer. It looks like the same PD3000 receiver as yours though I can't be sure:
https://www.youtube.com/watch?v=OXEtib5OnGI
* This is an external "Powered" sub woofer (powered amp and additional cross over "filter" to extract just the lower frequencies. The following you tube link is a detailed example of how this type of system works:
https://www.youtube.com/watch?v=ZpSAQDjuWN0
Aloha, ukeboy57
5 Related Answers
Anonymous
  • Posted on Nov 11, 2007
SOURCE: Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Anonymous
  • Posted on Mar 05, 2008
SOURCE: Rampage BA-100 200W amplified subwoofer
Actually. I don't think you have to wire a remote switch from the radio to the amp on this product. This powered subwoofer supposedly has automatic signal sensing turn-on circuitry. I have the same problem. So I think I'll try to just hook up the power (to the battery), ground and the + / - speaker wires to one of the back speakers in the car and see if that works.
Anonymous
  • 4234 Answers
  • Posted on Dec 16, 2008
SOURCE: How to connect unpowered subwoofer to receiver with RCA sub out?
In order for this to work, you will need an external amplifier. Your receiver is set up to use a "powered" sub. With only speaker connections on the sub, it is a "passive" sub requiring a separate amp.
Dan
Anonymous
  • Posted on Jan 07, 2009
SOURCE: connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Anonymous
    • 93 Answers
    • Posted on Feb 12, 2009
    SOURCE: best hook- up Polk psw10 sub woofer to yamaha rx-v663 receiver
    You will not need to y connect your subwoofer, if you have only one RCA sub out on your receiver the other end of the RCA connector cable goes into the left input on most powered subs, there is no loss of signal, the option exist as some receiver do sport a double RCA sub out.
    What cables will I need to properly install a pyle PADh212 1600w speaker cabinet with my pyle PD3000A 3000w receiver/ pre amp?
    rca cables connectors and use an 1/2 inch jack like a guitar lead. that will do it. i have my sub woofer set up the same way via a bass rig head to receiver
    1helpful
    5answers
    Broken connector in subwoofer connection on receiver
    The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
    How to wire sw8mk2
    Does the receiver, Have a (RCA) Jack on the back of the unit ,Where it is written sub out,If it does, You need what is called a sub conecter patch cord to hook up the sub.If it is a powered sub, If the receiver does not have a sub jack you can not hook up a sub to it.
    2helpful
    2answers
    Old receiver, new subwoofer- how to connect?
    NOOOOOOOOOOOOOOOOOOOOOOO! Never connect speaker outputs to anything that looks different, like RCA connections. Can you say crispy critter?
    Your receiver sounds like it won't send specific Subwoofer of Low Frequency Effects information to the Sub so we're cheating by adding a sub. If you named the model of each we may have a better shot at naming the output you need to use.
    I'm curious. How did you have the old passive sub working?
    Basically what you may have to do is feed (probable) full range audio to the Sub using an RCA splitter to combine the L and R outputs found, oh, at any Tape Output that you're not using. The Sub will only reproduce what it can. The presence of higher frequencies won't bother it. If it has its own volume control you'll be able to balance its volume with the rest of your speakers.
    How to install klipsch sub woofer to yamaha reciever rx-v559. everything working properly but sub wont be adjusted with volume. i got my stuff moved out here but had a mate help me set up. didnt pull it...
    Does the sub work at all? How is it hooked up? The sub needs to be fed by an RCA cable from the Subwoofer Output jack for the receiver to control its output.
    2helpful
    2answers
    Can't get my Accurian subwoofer to work
    Sounds like you have everything hooked up properly. Make sure the outlet is providing AC power to the sub. Check the power switch on the sub.
    If it is not working still; bring it back and swap it for another one before you warranty runs out.
    1helpful
    2answers
    Connect powered subwoofer
  • 0helpful
    Jensen vm9512
    you have to get a splitter so you can plug both RCA jacks into the sub output. Yes you can controll the sub volume from the unit. The center jack is another output for a center speaker.
    6helpful
    2answers
    Top RCA Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
