Question about Fuji Cameras
I have a Fuji S1000FP and for the most part it takes great photos EXCEPT when I take pictures into the sun then my photos are either white or black and no image. I will admit I just want a point and shoot camera because I don't understand shutter speed and such. However, I have attempted to change the shutter speeds and still nothing. I have tried all the pre settings as well. (This camera claims to be one of the better outdoor cameras. ) Can anyone offer words of wisdom on this. Ruth
  • 1 more comment
  • rajbuzzy Aug 01, 2009
    I realize that I shouldn't take directly into the sunlight and perhaps I worded my original question incorrectly. I should just have said in very bright sunlight it doesn't take. My sister and I have the exact same camera and she also has a kodak digital. Last weekend we experimented and took the exact photo shot with the two different cameras, the kodak worked but the fuji's did not. That is why we were thinking there must be something we are not doing correctly with the Fuji. Thanks Ruth
    Thanks, I look forward to hearing your response.
    I may not respond right away as I will be leaving the house but I will check in. Thanks
    You have been very helpful and prompt in helping me work on my problem.
  • 2,200 Answers
Hi
You should never take photos with any camera pointing towards the sun. It does not matter what advanced lense it has or what advanced settings - if you take photos into the sun you will get bad results.
The only exceptions to this may be photos at sunrise or sunset when the light of the sun is at its weakest.
See this link for some hints on setting exposure in these situations http://www.digicamhelp.com/how-to/nature/sun/
However as a general rule for point and shoot and family photgraphs etc .. you should always keep the sun at your back. Even strong light from one side can be an issue unless it is angled towards your back.
If you find your camera takes good photos when you stick to that rule the camera is not faulty.
There is very little even professional photographers can do about pointing into the sun. Simple rule - they avoid it!
Hope this helps. Please do rate my answer. Thanks.
Posted on Aug 01, 2009
  • Radio Code Pro
    Radio Code Pro Aug 01, 2009
    Thanks for clarifying the issue. The fact that both Fujis do this does tend to indicate an issue with how the lens is set up.
    If you bear with me I will have a look at this particular model and post up some tips you can try in one moment.
    Thanks
  • Radio Code Pro
    Hi
    I have looked at this issue extensively and in the absence of there being some type of internal fault with the CCD of the camera itself there are only a few potential issues I can advise that you should look at.
    When Auto is selected on the camera when you are outside in sunlight it should be identifying the ideal aperture settings etc .. and leave you free to point and shoot and not worry about advanced settings such as shutter speed etc.
    With this camera you have to press the shoot button half way to give it time to autofocus before you go ahead with the shot - this may be one aspect as if the shutter is rushed it does not help the results in the final shot.
    The other aspect is the white balance - under Auto this should be set up automatically - try the reset as outlined at the bottom of the page to see if this rectifies the problem. If not it might be worth going through the manual procedure for setting White Balance although this usually only applies to settings other than Auto.
    Finally if you have downloaded photos to your computer and found them to be dark then this will not apply - but there is also a menu setting for increasing the brightness of the LCD screen which in bright conditions may be giving the impression that the image is dark. If the photos have been found to be dark this does not apply.
    I would recommend that you reset the camera to its default settings and see if this makes a difference to the problem. To do this - press menu and under the spanner or wrench icon use the directional pad to go across to no 3. Enter the menu under 3 and find RESET and press the right key on the directional pad to get a confirmation message. Select OK and press MENU/OK
    This resets the camera to factory default settings. If severe image problems like you describe are persisting after this it would seem there must be some internal component issue that is effecting the images as although image quality can vary to some degree between cameras there should not be severe image problems like you describe happening in broad daylight.
    Do let me know how you get on. Thanks.
Some pictures are black and with only one color identfied
This company is very good and handles Fuji with excellence! http://www.teleplancamerarepair.com/Fujifilm_FinePix_S7000
As part of your repair they also clean the camera which is quite nice
Jul 01, 2010 | Fuji FinePix S7000 Digital Camera
Fuji S6000fd; black display, both lcd and viewfinder
I have the same problem except everything is white, not black.
Jul 05, 2009 | Fuji FinePix S6000fd Digital Camera
How to take black an white pictures with the fujifilm A850
Hi
check in the settings if you have option for sepia or grayscale. choose this and photos will be in black and white.
Hope this helps
May 13, 2009 | Fuji FinePix A850 Digital Camera
Photos are "whited" out, like a burned out image in the center
Did you point it at the Sun?
I think you have burned out the CCD/CMOS sensor.
The display wont have been affected.
If its not insured for accidental damage, its a bin job!
Apr 29, 2009 | Fuji FinePix S7000 Digital Camera
When taking photos in direct sun photo is all black. i have Nikon Collpix 4600 My camera turns on perfectly fine. Everything works great, except for the fact that the screen shows nothing. It is a black...
contact NIKON BAD CCD PROBLEM !
Get ir repaired free of charge just call them thousands face the same problem and all brands are repairing it free go call them
see the link for widespread Bad CCD problem dont worry if u are not on list but u have the same problem call them PLS RATE ME FIXYA for help !!
http://www.imaging-resource.com/badccds.html
Apr 12, 2009 | Nikon Coolpix S210 Digital Camera
Can't get date to print on photos from S1000fp camera
The instructions to print the date and time on your pictures is in your manual on page 91. If you need the manual you can find it here:
http://www.fujifilm.com/products/digital_cameras/s/finepix_s1000fd/pdf/index/finepix_s1000fd_manual_01.pdf
Let me know if you have any problems.
Rob
Mar 09, 2009 | Fuji FinePix S700 Digital Camera
PIctures
A good photo shop type program will let you turn colour into black and white pictures easily. Paint shop pro has been a standard and favorite of mine since it came out. Lots of editing functions and lots of interesting extras to play with.
I believe the latest version is PSP12
good luck and happy editing
May 22, 2008 | Fuji FinePix A120 Digital Camera
Faulty pictures
My camera has the same condition. What happened and can it be fixed??
Nov 07, 2007 | Fuji FinePix S20 Pro Digital Camera
Fujifilm finepix A500
This camera does not have the facility to take "black & white" photos. However it is easy to convert the colour pictures to black & white using software once they are on your PC. Here is a great FREE utility that will do what you need: http://perso.orange.fr/pierre.g/xnview/enxnview.html If you need any help with it let us know. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 25, 2007 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Cameras Logo
44 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
