Question about Hayward 250kbtu Ng Pool Heater - Inground
Hayward H250 -Gas. I was turning the temp up and the whole display panel went out. The unit is less than 6 months old. Power supply is fine. How do I get this unit back on?
  • Linda Yurkin May 11, 2010
    I have the same unit with the same problem right now. Did you find out what it is? We are working on it. Thanks.
    President:
  • 1,486 Answers
Turn off the power and leave off for an hour then turn back on.That should reboot the system.
Posted on Aug 01, 2009
Hayward H250 has LO listed on the electronic panel after it had been blowing black soot out of it
check gas pressure heater overheated probably needs hi limits or fusible link plus clean heat exchange to solve
Oct 12, 2012 | Hayward H-series Electronic Gas Pool...
Hayward h250 ed2 failure error code IF
ignition failure check gas source if ok check ignitor
Aug 03, 2012 | Hayward H-series Electronic Gas Pool...
Remove high stack from Hayward H250 series pool heater
clean stack also check gas pressure sooting caused from low gas pressure plus overheating
May 25, 2012 | Hayward H250 High Wind Stack
Pf hayward error code on gas heater H250 IDPL1
check pressure switch if voltage both sides ok if not bad switch or clogged copper tube also check filters
Nov 16, 2011 | Hayward H-series Electronic Gas Pool...
Heater was running and displayed ce code then it went to displaying water temp then stopped running and no display or lights on at all on the panel
There could be multiple things that could cause no lights to be on the panel and here are some of them, defective panel board, now power being supplied to the heater, defective power supply, etc. One way to resolve this issue is to get a schematic, volt/ohm meter and use it to make sure power is getting to the panel. If power is getting to the panel board then it is most likely defective. If there is no power getting to the panel board then you will probably need to call the Hayward technical support at 908-355-7995 and they should be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 24, 2011 | Hayward H Series Pool & Spa Heater 400k...
I have a hayward h250 with an sf code
This is farley easy to change out and pretty inexpensive at the same time. You will find this on the top left side of the plumbing manifold. It slides into the manifold and wires run back to the thermostat on the front panel. Chech your wires and the connections at the temp control before you replace the part. Good luck.
Jun 13, 2009 | Hayward H Series Electronic Ignition...
Hayward h250, wont heat
Sounds like it could be the flame sensor.
Apr 04, 2009 | Hayward H Series Electronic Ignition...
Hayward 250kbtu Ng Pool Heater - Inground Logo
238 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
