Question about Dryers
Broken Belt any tricks to change belt - Dryers
    President:
  • 1,714 Answers
Yes, watch this for help
Posted on Aug 01, 2009
Best way to replace belt on model # 11086581110
watch this video it shows you how :)
Blessings
Larry
Mar 03, 2015 | Kenmore Dryers
Belt comes off when it rains
THEN CHECK THE DRIVE BELTS THAT IS WHERE THE BELT RUN (DISKS) OR BUY THE BELT BUT A OEM ONE NOT THE REPLEMENT OR GENERIC.
Jan 10, 2012 | 1998 Dodge Grand Caravan
Thinking of buying a peugeot 307 with 124k, will changing the timing belt make a difference?
If the belt is broken, pass on buying it. Broken timing belt = BIG $$$ repair. If it's running and price is right, w/that many miles get timing belt changed ASAP.
Feb 23, 2011 | 1989 Mercury Tracer
The brush doesn't spin anymore, but the belt is not broken. model DC 07; approx three years old
The belt may not be broken but after 3 years the belt will have stretched and it will not turn the brush. You should change the belt every year. Changing the belt is an inexpensive fix. I would try that first and if it doesn't do the trick I would take it to a repair shop. You can get the belt you need here:
Dyson DC07 Replacement Belts
Nov 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My vacuum has suction the belt is good i cleaned the filters but it won't pick up nothing
The belt may look good and not broken, but it could still be stretched or worn. I would try changing the belt, I bet it does the trick! You didn't specify a model but you can get just about any belt here:
www.vacbelts.com
Oct 18, 2009 | Vacuums
My hotpoint vtd20 dryer is vibrating when running. When stopped, with my hand i can barely turn the drum (not sure if it turned easily before) any advice?
hi Step 1: Locate the belt by removing the back or front service panel. Depending on the type of dryer you own, you may have to prop up the drum to keep it from sagging. Don't let the drum hang; the bolts that hold it in the cabinet could be damaged. Don't remove any more parts than necessary.
Step 2: Identify the belt. The old belt may be threaded around the idler pulley and motor drive shaft. Draw a diagram showing how the pulley is installed so you'll be able to replace it properly. If the old belt is worn or frayed, but not broken, leave it around the drum as a pattern for positioning the new belt; cut the old belt and remove it when the new belt is in position.
Step 3: Remove the old belt from the pulleys and stretch the replacement belt into place. The new belt must extend around the dryer drum and the pulleys. The trick is to align the belt on the drum with the pulleys -- the ribs on the new belt go against the drum.
Step 4: Once the belt is aligned, turn the drum by hand, if possible, to make sure the belt is tracking. You may have to reassemble part of the cabinet to do this.
Some older dryers have a V-belt pulley drum drive. With this system, two or three pulleys of different sizes set the speed of the drum. To change this type of belt, decrease the tension on the idler pulley and install the new belt in the V-grooves of all pulleys. Then place the idler pulley back into position.
With any dryer, make absolutely sure that you replace the old belt with a new one made especially for the dryer. Any difference in belts can change the speed of the drum and cause problems with other dryer components.
thank u................
Sep 12, 2008 | Dryers
Dryers Logo
97 people viewed this question
Top Dryers Experts
