Question about Dryers
Gas dryer does not heat up. Gas is on and the
Gas dryer does not heat up. Gas is on and the unit is plugged in.
  • 6,784 Answers
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Aug 02, 2009
No heat, I have verified 220 service both breakers are not tripping, 220 plug gets current. No obstruction in vent also ran without vent pipe attached I did notice last night sensor dyer level light...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 03, 2011 | Maytag MDE9700AYM Electric Dryer
Dryer is not heating up it runs does the ignitor heat up before gas valve opens because the ignitor never heats up
On my gas appliances, either there is a pilot light or the ignitor sparks (like a car spark plug) or glows after the gas valve opens. The ignitor does not heat up.
I've had some gas appliances that have had the valve stick. (On an oven, we tested this by tapping on the valve when the unit should have called for gas. This confirmed that the valve was bad and not the thermostat.)
I hope this helps.
Dec 07, 2010 | Amana NDG7800AW Gas Dryer
Kenmore gas dryer no heat,cleaned unit glow plug doesnt ignite
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 10, 2010 | Kenmore Dryers
heatman101
Oct 10, 2010 | Kenmore 72872 Gas Dryer
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Hi, i have an amana dryer, model LG8409w2. it is running but has no heat. is this a gas dryer? and how do i get into it to see what's wrong. thanks
Hi, to tell if it is gas or elect, just pull it out some and look behind it. A gas dryer will have a galvanized pipe with a gas flex line and shut off valve going to it. If electrical, it will have a large diameter cord plugged into a large round plug much different then a regular receptacle. It sounds as though it is a electric dryer as it is running. A gas dryer will have a regular plug on it to. If no heat, it could be a number of things that are wrong. The heat strips are located at the rear of the dryer behind the panel. You will need to unplug it and pull it out to do this. Give yourself lots of room with a strong light to work with. The heating element has several coils of wire lined up in a vertical position. Look them over very good for a break in any part of these coils, look very carefully to find one. If you do, you will need a new one. Take the model, serial, and name to a appliance parts house to get one. If by chance it is gas, make sure there is gas to the unit and the valve is open. Shut off the valve and take loose the line. Crack open the vale a little to hear and smell the gas. There is not much you can check on a gas dryer but this, that's about it. It may be the ignitior, a thermostat ect. I am sure you have a electric dryer, so check the element and clean all of the lint from the unit. Get back to me on this, so we can go further if needed.
Sincerely,
Shastalaker7
Jun 12, 2010 | Dryers
My gas dryer is not heating up I checked to see if any flames is on when its running but its not coming on the timer is turning.what needs to change
All gas dryers have a gas module. The older models (very old) have a pilot light and the new ones have what is called a GLOW PLUG and it is made out of ceramic. If this glow plug is in any way broken, you will not have any heat. The GLOW PLUG is what comes on when you first turn the dryer on and it GLOWS until the gas module actually spits out a small amount of gas and an internal combustion occurs and the flames come on full power and this is what dries your clothes. If the GLOW PLUG is fine, then the gas module could be bad. ALSO, Always check for burnt wires and check any thermostats or fuses internally in the unit.
Nov 16, 2009 | Whirlpool Dryers
Gas dryer is not heating now.
That unit should have a glow plug igniter. No pilot. Please be carefull lots of lent to catch fire. Good luck
Nov 09, 2009 | Heating & Cooling
The dryers does not light
I will be happy to assit you with this issue
I have a web side that will help you.
http://www.youtube.com/watch?v=f1rebeCMVsk&feature=fvw
was this helpful?
your rating is very important so I can help others.
thank you
Oct 18, 2009 | Kenmore Dryers
Dryer turns and timer works - just no heat ? What is the problem?
If it's a gas dryer, check the thermal fuse in the rear in unit,, a lead on each end,,white plastic with a hump on it,,,careful it's live if unit is plugged in
Apr 20, 2009 | Maytag Performa PAV2200
Dryers Logo
82 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
