The front roller on our Ultima 65 has two large "bubbles" on either end of the roller thus causing the film to crinkle on either side of the "bubbles." Can we get a replacement roller?
SOURCE: 1995 Taurus motor mounts
these are known as cradle bushings. the frame around engine is called the cradle. you can get mounts from ford should just replace these and be fine
SOURCE: Large electric burners not working on lowest "LO" setting
Unplug the range and remove the problem elements.
With a flashlight, look inside the element receptacle for burned or disfigured terminals.
If they are damaged they can be replaced.
If the element terminals are OK you have defective switches.
SOURCE: replacing front driver side (F150) brake line (rubber hose)
Brake fluid is highly corrosive. If you can't get the line loose on the frame side then I would suggest replacing the hard line as well coming from the master cylinder. Or if you have a flaring tool you could cut the hard line just behind the rubber and put a new fitting on it. Pretty easy if you have the tool. Essentially you will wind up kinking or breaking the hard line anyway if the fitting won't come loose easy.
SOURCE: What would cause the battery to heat up so hot that it would boil
It sounds like the voltage being applied to the battery is way too high. If a 12V system, it shouldn't exceed 14 volts, half that for 6 V systems. If you don't have a meter, buy one at Radio Shack or any auto parts store for < $20 US or if near a Harbor Freight Tool store <$10 US. Ask for a digital multimeter.
