Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
Store jet transcend 160gb not detected - Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
  • Jignesh Khare
    Jignesh Khare May 11, 2010
    Check the data cable if it is working properly or not? and try to connect to different USB port first we need to check if ur computer is not accepting it or its the storage problem...
  • 3,153 Answers
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
3 Suggested Answers
  • 10 Answers
SOURCE: my laptop cannot detect my
First, if you're using a version of Microsoft Windows, right click "My Computer" and in the menu, click "Manage"...
On the left hand side you should see "Disk Management"... Click on that and give it a few moments... If it pops up there, you're doing good so far...
It will give you some details about your drive, if it's healthy or not, partitioned/formatted or not etc...
You'll probably have to format it to have it work and show up on your computer.
Hopefully, it's not broken! I hate buying used parts that are broken...
Posted on Jan 30, 2011
bronk50
  • 27725 Answers
SOURCE: Store jet transcend 640gb not
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on May 23, 2011
How to partition transcend hard drive
http://download.cnet.com/minitool-partition-wizard-home/3000-2094_4-10962200.html
A full-featured disk management utility is something most experienced Windows users need, whether it's to add and format a new hard drive, configure a USB drive, or copy partitions or whole drives and move them to new drives.
Freeware
Hope this helps
Oct 30, 2012 | Transcend 160GB STORE JET PORABLE HDD 25...
Transcend store jet 25 mobile 160GB hard disk...when i connected to laptop it is not connecting.......one button is on Hard dish..if i press the button and hold it upto i put the usb cable in to laptop...
Go to www.transcendusa.com, this is official site for transcend products. You will find there a little program to restore functionality of your hdd (this in case hdd have no bads on disks), run this program and see after that if is ok. Good luck!
Mar 21, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My transcend jet flash drive is not detected on system. details are as follow:Transcend jetFlash RV10 8gb
Hi friend,
Your trnscend jet flash drive is damage so you need to contact nearest hardware service centre they will repaire it ...
Jan 06, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My 4 GB transcends jet flash pend drive is not detected
No softwares can solve it seems you have alreadyshot it by using it in usb slot that was not connected correctly
Jan 19, 2009 | Transcend (589307) Media
Transcend jetflash 2GB no detecting
ny Transcend jet flash 2GB fingerprint not recognized, any help fpr me pls to format or to find any solution for this problem...
thanx
Basman
Nov 01, 2008 | Transcend (589307) Media
Transcend jet flash
it might b due to problem in your  flash drive... anyway  go on www.transcend.uk      select ur device... then there will b a software ...u also can get firmware..
Jul 03, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Transcend pen drive 2GB not getting detected
Sir: Transcend pen drive 2GB not getting detected Can you suggest anything?
Feb 27, 2008 | Transcend (589307) Media
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
2,224 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
