Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
The spark module keeps firing once every 30 seconds when turned off.
  • 15,935 Answers
Please clarify "spark module"
THanks
Posted on Aug 01, 2009
Why does my powerhouse PH3100ri generator run fine for about 5 minutes or so then dies and it will not start again in till it sets for 30 minutes or so then it will fire right up please help!!
Maybe faulty CDI ignition module ? There are a number of components ( electrolytic capacitors ) in the module that can fail with temperature rise.
A test... Remove the ignition plug lead when motor has stopped after the 5 minutes and put a wire inside the plug cap and place end near a metal part of motor. Careful not to zap yourself... Pull starter and look for ignition spark. If there is no spark then probable fault is ignition module. If there is spark then problem may be in fuel system.
Do check vent on fuel tank is open.
Do check choke is turned to off once motor is running.
Do check the oil level as the low oil cutoff can cause shutdown and will result in no spark.
Mar 16, 2015 | Powerhouse PH3100Ri Inverter Generator...
Why 1996 f 250 turns over good but will not start all fuses good ?
Several possibilities. Either no ignition or no fuel to the cylinders.
First determine the fuel pump is running when you crank. If may have failed. You will have to crack open a fuel line (or install a service test gauge and measure the pressure).
Second -if fuel pressure is good-- no ignition spark. If there is fuel and fire--its gotta run. No spark can be caused by 1) crank angle sensor --measures the rotation and decides when to fire -automatically sets the timing. If no signal, no spark. Fuel injectors also will not open.
2) Engine 'ECU' faled/malfunction'. Ford (Motorcraft )made for many years ignition control modules with a defect in the circuitry. Every once in a great while --no spark. You could 'reset' the module by briefly (just a spark touch) by reversing the battery connections
Jul 23, 2014 | Ford F-250 Cars & Trucks
GE profile gas cooktop - sparker firing with knobs turned off?
replace your spark module
have you spilled liquid on the cooktop recently?
if yes let it dry for a couple of days and see what happens.
sometimes when you spill liquid on the cooktop it grounds out the spark module and it will continue to spark until it drys.
let me know if you need more help
Feb 15, 2010 | Cooktops
Hi, I replaced the right side ignitor module and now the ignitors spark vigorously and the burners light but the ignitors won't spot sparking and sometimes keep sparking several seconds after I turn off...
There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. The next thing to check for are theignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
thanks.keep updated and please do accept the solution.
Sep 18, 2009 | Viking 30" Professional Select Built-in...
Frigidaire Gallery stove top spark module is firing once every 30 seconds when turned off.
ok - this is a question regarding a stove - not a fridge - as indicated.
:D
If the ignitors on a gas stove top continuously spark and only stop when the electricity is turned off the problem may be a stuck relay.
Turn off the electricity (unplug) for a long period of time perhaps overnight. Sometimes the relay will automatically reset.
Aug 01, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Have Jenn-Air 36" gas cooktop w. 5 burners, black. Mdl JGC8536ADB. Plastic knobs keep splitting, even if we remember to push down before turning. Have replaced two sets and now we're down to two working...
Hi
Thanks for using FixYa. There are a few things to check for. Make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and not a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it.
The switches or the range control knobs may have got wet and are completing the circuit to the spark module thus causing it to continuously click or fire off sparks continuously. Use your hair/blow dryer and blow some hot air around the spark module area.
This is a typical spark module wire diagram--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 31, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
HELLO MR BEAN
These problems are difficult to diagnose sometimes without being there to actually see what is going on. Now...let me see if I can remember all of this. You replaced the spark module and have a spark at each burner now. You also checked for gas leaks and didn't find any. Now, you're telling me that the oven isn't working? Most oven igniters I'm familiar with are the glow bar type. Which means they don't spark at all. They glow to a certain current potential (roughly 2.7 to 3.3 amps) before the gas valve is opened and begins to flow. Once gas flow is achieved, the igniter ignites the gas. Now, when these igniters get old, they become weak and will not provide enough current to open the gas valve, or, they take a long time to ignite. If this is your case, then you need to replace the oven igniter. Does this help you? PS Keep in mind, some ovens have two separate igniters. One for the broiler and one for bake. Does the broil function work? If so, the oven switch is good.
Aug 07, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Spark igniters on the burners fire continuously
Had The same problem. I removed the top of the control panel to find out that one of the ignitor switches had turned when I replaced the four large plasic nuts on the control panel. Make sure the switches (block) are aligned, and kept aligned, when re-installing the top of the control panel. Startwreck.
Jul 15, 2007 | KitchenAid KGST307 Gas Kitchen Range
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
21 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
