Question about Kenmore Dishwashers
Kenmore Ultrawash Quiet guard 3; can't get the clean light to turn off to be able to start cycle
  • 15,935 Answers
Try pressing normalwash-heatdry-normalwash-heatdry-normalwash-heatdry-normalwash-heat then all the lights come on.
Let run for a little bit. then keep pressing the start button... until the unit shuts off, then try running a cycle.
The control board has a memory in it. So if you have cold water running in it one time. It will take longer to warm up. Your memory in the control board says its taking to long to warm up. Shutting down thinking there is something wrong with your heating cycle.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Aug 01, 2009
  • blueextc3221
    blueextc3221 Aug 01, 2009
    after all the lights come on, you can simply stop pushing buttons and wait.
    The unit will start up on its own after a couple minutes.
Model 665.13732k600 seriel FT4610713 dishes are not getting clean, they look like they have a film on them. Kenmore Ultrawash Quiet Guard Deluxe
The film is the stuff and the old soap backing up in the dishwasher. There is no cure for this. You can have them come out and it won't get fixed because it will happen again. They did not put a large enough drain/disposal on the models. Essentially you are eating old soap - goodness only knows what is in it.
Jan 01, 2010 | Kenmore Dishwashers
Kenmore Ultrawash Quietguard Deluxe Problem
kenmore washers nothing but problems, my washer says clean and will not do any cycles...... less that 2 years old
Oct 21, 2009 | Kenmore Dishwashers
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Kenmore 665.17539. fills but does not wash. makes
Kenmore 665
My dishes on the top rack are no longer getting clean. I don't think any water is going to the top. The dishes on the bottom get clean but have a soap residue on them.
Jul 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
The IRONY of my Quiet Guard!! SO LOUD!!!!
Yes the wash arm can be removed to get to the sump area. Take the model number for your dishwasher and enter it into a site like partselect.com. There you can get a blown up diagram of the components that need to be removed to get to the cause of the grind noise. Usually a seed or some other hard object has found its way down there.
Feb 06, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Dishwasher 665.17979301 - Reset Sequence?
Try pushing the Sani-Rinse and Air Dry buttons back and forth a number of times.
Apr 20, 2007 | Kenmore 24 in. 15142 Built-in Dishwasher
Open Questions:
Dishwashers Logo
176 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
