SOURCE: Fisher & Paykel GWL11 Top-Load Washer troubleshooting
I've had my washer for about 8 years. I experienced the same problem - pump stopped draining the machine. I called F&P and "Patrick" told me that I need to 1) unplug the machine, 2) tilt up the front of the machine, 3) spin the pump (plastic blades) until they turn freely (usually counter clockwise) but I turn it both ways till it turns freely, 4) plug the machine back in and press the buttons to get it back where it was - this has worked every time to get the machine going again. I do a lot of "dog laundry" and I'm sure the rugs/dog hair cause the problem. Hope this helps!
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
SOURCE: what is error code 136 on a fisher & paykel IW...
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
SOURCE: I have a Fisher and Paykel Saffron oven - stove to...
The temperature switching device has 'died', and needs replacing. This is a continual problem in these stoves (we have replaced each of ours at least once or twice in the 7 years we have had it). I will never buy another F&P oven!
The only solution is to get F&P or another repairman to come out and fix it. It cost us $AU 215 each time.
